New approach to Rotary Encoder
Results 1 to 40 of 91
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: New approach to Rotary Encoder
    It a real pleasure to see how generous some people can be ... Thank You, AGAIN, Mr. Henrik !
    ...I think I missing something ... If UP do something, If Down do something else...dont ?!
    But nothing happens.
     @ DEVICE pic16F628A, XT_OSC, WDT_OFF, PWRT_ON, BOD_OFF, MCLR_ON, LVP_OFF
       Define   OSC 4           ' 4MHz
       CMCON = 7                ' Disable on-chip comparator, PORTA in digital mode
    include "alldigital.pbp"
    TrisA = 000000
    PortB = 010000
    TrisB = 000000
    oldState VAR BYTE
    newState VAR BYTE
    Q_Count VAR WORD
    DIR VAR BIT
    UP CON 1
    DN CON 0
    Main_Loop:
    newState = (PortB & 100000)
    goto encoder
    if dir = up then portb.0 = 1
    if dir = dn then portb.1 = 1
    goto Main_Loop
    goto encoder
    if dir = up then
    portb.4 = 1
    portb.0 = 1
    if dir = dn then
    portb.4 = 0
    portb.1 = 1
    goto Main_Loop
    encoder:
    If newState <> 0 THEN
    If newState <> oldState THEN        ' Changed from last time?
      Select Case oldState
        Case 32
        If NewState = 128 THEN          ' Was 1 now 4 = Up
          Q_Count = Q_Count + 1
          DIR = UP
        ELSE                          ' Was 1 now 2 = Down
          Q_Count = Q_Count - 1
          DIR = DN
        Case 64
        If NewState = 32 THEN        ' Was 2 now 1 = Up
          DIR = UP
        ELSE                           ' Was 2 now 4 = Down
          DIR = DN
        Case 128
        If NewState = 64 THEN        ' Was 4 now 2 = Up
          DIR = UP
        ELSE                       ' Was 4 now 1 = Down
          DIR = DN
      END SELECT
      oldState = NewState
    Or I wired the roller wrong ?
    Here ( http://www.angelfire.com/nd/maza/kenwood.html ) it's a working variant, but in other "way" , using Atmega ...
    Try GOSUB Encoder and put a RETURN at the end of the subroutine. Currently you GOTO Encoder and then you run off into never never land. I'm not saying that will make it work but that's one possible problem.
    Also, make sure that have the "wiper" of the roller connected to 5V, verify that you get signals on the actuall pins of the PIC when you rotate the encoder/roller.
    Dec 2008
    Ploiesti, ROMANIA
    I think the hardware must be build in this way (since the rest of buttons are allready connected as matrix). I wonder if "KeyPad.bas" of Mr.Mister-e can be addapted to read the increment/decrement of roller, by "including" somehow the code for encoder ....
    Brrrrrr...it's beyond of my intellectual capacities .
    I don't have any experience with that routine but provided everything else works the way you want why don't you just set the pin which is common to the encoder (RB5 ?) high, read the port, and return the pin low.
    GOSUB ScanMatrix 'Or whatever
    PortB.5 = 1
    GOSUB Encoder
    PortB.5 = 0
    Finally, in the first code you posted you had the encoder to RB7-5 so I based my code on that. Now, in your latest schematic, you have it on RB2-0 which means that my code (if that's what you're trying) definitely won't work without modifying it since it expects the three "switches" in the encoder to be on RB7-5.
    Dec 2008
    Ploiesti, ROMANIA
    What I do wrong ?!
    I adapted "keypad.bas" to my hw :
    KB_ROW        = 3                                      ; 3 ROW keypad
    KB_ROW_PORT   = PORTB                                  ; Keypad ROW on PORTB
    KB_ROW_BIT    = 3                                      ; ROW0 = PORTB.3
    KB_COL        = 3                                      ; 3 COL keypad
    KB_COL_PORT   = PORTB                                  ; Keypad Col on PORTB
    KB_COL_BIT    = 0                                      ; COL0 = PORTB.0
    DebounceDelay = 0x80                                   ; debounce delay 41mSec
    SINGLE_SCAN   = 0                                      ; Scan ;till a key is pressed
    KEYPAD_AUTOREPEAT = 1
    and I wrote this pice of code :
       Define   OSC 4           ' 4MHz
    include "C:\PBP\enc_KEY.BAS"
    TrisA = %00000000
    PortA = %00000000
    PortB = %00111000
    TrisB = %00011000
    oldState VAR BYTE
    newState VAR BYTE
    Q_Count VAR WORD
    DIR VAR BIT
    UP CON 1
    DN CON 0
    Main_Loop:
    newState = (PortB & %00111000)
    portb.5 = 1
    gosub encoder
    portb.5 = 0
    if dir = up then
    porta.0 = 0
    porta.1 = 1
    if dir = dn then
    porta.0 = 1
    porta.1 = 0
    goto Main_Loop
    encoder:
        Case 32
          DIR = UP
          DIR = DN
        Case 64
          DIR = UP
          DIR = DN
        Case 128
          DIR = UP
          DIR = DN
      END SELECT
      oldState = NewState
    ..but no change in porta.0 or porta.1 state ...
    Dec 2008
    Ploiesti, ROMANIA
    Update code :
    Main_Loop:
    gosub keypadscan
    newState = (PortB & %00000111)
    gosub encoder
    gosub check
    goto main_loop
    Check :
    if dir = up then
    porta.0 = 0
    porta.1 = 1
    if dir = dn then
    porta.0 = 1
    porta.1 = 0
    encoder:
        Case 32
          DIR = UP
          DIR = DN
        Case 64
          DIR = UP
          DIR = DN
        Case 128
          DIR = UP
          DIR = DN
      END SELECT
      oldState = NewState
    but no matter what M (1,2 or 3) I push, porta.0 goes high and stay so.
