Here I post an update of the code posted in #18. This new code has a more efficient ISR so it can read at higher frequency. I don't know the maximum frequency that the system can acheive, so if someone with some spare time will give a try and post the result, could be useful.
As the previuos code, the mainloop doesn't do much, it simply update the display.
Here the code revised:
CheersCode:' PicBasic program to demonstrate how to read an optical encoder ' in quadrature. The code uses a 2 lines LCD in 4-bits mode ' **** MCU USED: PIC 16F628 *** ' ' ------------------ LCD should be connected as follows ------------------- ' LCD PIC Port ' --- -------- ' DB4 PortA.0 ' DB5 PortA.1 ' DB6 PortA.2 ' DB7 PortA.3 ' RS PortA.4 (add 4.7K pullup resistor to 5 volts) ' E PortB.0 ' RW Ground ' Vdd 5 volts ' Vss Ground ' Vo 20K potentiometer (or ground) ' DB0-3 No connected '------------------------------------------------------------------------- ' Encoder channel A PortB.6 (use pullups resistor if necessary) ' Encoder channel B PortB.7 (use pullups resistor if necessary) ' N/U PortB.0 (output) ' N/U PortB.1 (output) ' N/U PortB.2 (output) ' N/U PortB.3 (output) ' N/U PortB.4 (input - to be grounded) ' N/U PortB.5 (input - to be grounded) ' '------------------------------------------------------------------------- INCLUDE "DT_INTS-14.bas" ' Base Interrupt System (by Darrel Taylor) DEFINE OSC 20 eeprom 0,[2,0,3,1,1,3,0,2] Define LCD_DREG PORTA Define LCD_DBIT 0 Define LCD_RSREG PORTA define LCD_RSBIT 4 define LCD_EREG PORTB define LCD_EBIT 0 define LCD_BITS 4 define LCD_LINES 2 define LCD_COMMANDUS 2000 define LCD_DATAUS 50 CMCON = %00000111 TrisA = %00000000 TrisB = %11110000 PortB = 0 Flag var bit wsave VAR BYTE $70 SYSTEM ' alternate save location for W Q_New var Byte Q_Old var byte M_Count var byte [4] P_Count var byte [4] Q_Count var word ' ---------------------- Set variable value @ startup ---------------------- For Q_Old = 0 to 3 Read Q_Old,M_Count[Q_Old] Read Q_Old + 4,P_Count[Q_Old] Next Q_Old Q_Count = 0 Q_New = 0 Q_Old = 0 Flag = 0 ASM INT_LIST macro ; IntSource, Label, Type, Resetflag? INT_Handler RBC_INT, _Encoder, ASM, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE RBC_INT ; enable external (INT) interrupts '---------------------------- Initialize LCD ---------------------------- Lcdout $fe, 1 ' Clear LCD screen Lcdout "System Ready" ' Display message Pause 500 ' Wait .5 second Goto Main_Loop Encoder: ' ISR Q_New = PortB.7 + PortB.7 + PortB.6 ' get port status If M_Count[Q_Old] = Q_New then ' if M_Count code satisfied then minus Q_Count = Q_Count - 1 Flag = 1 ' set flag to true to update display goto Q_Skip endif If P_Count[Q_Old] = Q_New then ' if M_Count code satisfied then plus Q_Count = Q_Count + 1 Flag = 1 ' set flag to true to update display endif Q_Skip: Q_Old = Q_New ' update Q_Old Byte @ INT_RETURN Main_Loop: if Flag = 1 then Lcdout $fe, 1 ' Clear LCD screen lcdout dec Q_Count ' Display encoder position (counts) Flag = 0 ' reset flag to false, display updated endif goto Main_Loop end
Al.
Thanks! Aratti...
I had just finished adapting your earlier example for a 16F690 pic. It took me a while to figure out why my LCD was not working... Dang MCLR pin tripped me up untill I rememberd that it could not act as an output... then I had to move my LCD to PortC... then I had to figure out that my OLD 4 line LCD (bought it about 20 Years ago from AllElectronics) needed more time on the LCD_COMMANDUS.
Anyway it is working GREAT...
I will give your latest code a spin this weekend.
As far as update time to the LCD... it seems to be limited to any Pause or other code that is in the Main Loop. I had been blinking an LED in the main loop using a Pause statement and therefore this limited the LCD update frequency. I think I'll try and impliment another DT-Int using a timer to run the blinking LED in the main loop. This should remove any excessive delay to the LCD update.
PS. I can post Aratti's modified working code for the 16F690 if anybody is interested...
Dwight
May I offer insight into another way around this problem? I've always been concerned about the overhead of printing to an HD44780 compatible character display. For example, if you tie up the processor for 400 usecs while printing eight (8) characters to the LCD, you might have a problem with another process that needs to run at 100 usec intervals. Instead of updating the display the usual way, with a 40 usec delay between each write, why not refresh the LCD from a 32 character buffer as a background task using interrupts. I did this recently on a TI MSP430 Launchpad project and it worked very well.
Here's the basic idea (C code). Your main program simply writes ASCII data into a 32 character array to update the display. Array elements 0-15 and 16-31 are mapped to LCD lines 1 and 2, respectively. The driver in the ISR only writes one character at a time from the array to the LCD during each interrupt, but I used a 500 usec interrupt interval so the entire display is actually updated around 59 times each second (updates are perceived as instantaneous). Also note that the PutLCD routine (not shown) does not need to include the normal 40 usec LCD inter-character delay.
Food for thought... Regards, Mike
Code:unsigned char lcd[32] = { " " };Code:void interrupt() { // 500 us TMR2 interrupts static char bndx = 0x00; // lcd display buffer index, 0..31 static char line = 0xC0; // lcd display DDRAM address pir1.TMR2IF = 0; // clear TMR2 interrupt flag /* * * refresh one character on the display each interrupt. entire * * display refreshed every 17 msecs (58.8 Hz refresh rate). * * */ if(line.7) // if "new line" PutLCD(line ^= 64,0); // toggle LCD DDRAM "line" address else // not "new line" so PutLCD(lcd[bndx++],1); // refresh display, bump index bndx &= 31; // pseudo mod 31, 0..31 inclusive if((bndx & 15) == 0) // if new line (0 or 16) line.7 ^= 1; // toggle b7 pseudo "new line" flag }
For some peculiar reason that I cannot understand, Al's code is counting +/- 4 steps instead of one for each click.
Anyone can speculate why?
With a logic analyzer I have confirmed that the encoder is working fine. Here is a snapshot for 4 clicks of the encoder.
Hi Ioannis,
I haven't looked at the particular code in question but generally, you decode all 4 edges, hence the term quadrature. Look at the capture for one click, first Ch.0 goes low (1) then Ch.1 goes low (2), then Ch.0 goes high (3) and finally Ch.1 goes high (4). So, 4 counts per click.
Hmm, thanks Henrik, it looks logic now... well...
