Triggering 5 TTL clocks simultaneously
Results 1 to 40 of 84
    mmm, are you saying PWM stops when you jump CCP1 to RB0? what about if you do a simple blink on this RB0 pin... or do a simple IF THEN on RB0
    IF PORTB.0 = 1 then DoSomething or Start HPWM
    maybe this pin is burn now
    TurboLS's Avatar
    TurboLS Guest
    So you are saying that my code is right and the pin is just acting weird? If it is burned, I have like 8 more PIC chips. I just want to make sure that the problem is fixed before I burn another one. So I will test this PORTB.0 with a simple blink program to see if it responds at all. I'll let you know what happens. Thanks again for your continued input.
    Do the RB0 test before using others.
    BTW, i'm about setting up a board to do something like this for testing. ì'll post the code here.
    This one use RB0 interrupt handler routine.
        ' INT0 with PWM
        ' File name :  INT0_PWM.bas
        ' Company : Mister E
        ' Programmer : Steve Monfette
        ' Date : 02/03/2005
        ' Device : PIC18F2320
        ' This program generate 3.6Khz @ 25% duty PWM on CCP1 pin.
        ' CCP1 pin is connected to RB0 pin via 1k resistor.
        ' Program blink a led on PORTB.6 while generating PWM.
        ' Each rising edge of PWM, PORTB.7 is toggle.  This will
        ' generate 1.8Khz 50% duty on this PORTB.7 pin.
        ' We will use Interrupt on RB0(INT0) pin to detect rising edge
        ' Hardware Definition
        DEFINE LOADER_USED 1
        DEFINE OSC 20
        TRISB=%00000001   ' PORTB.0 as input
        TRISC.2=0         ' PORTC as output
        ADCON1=$0F        ' disable A/D converter
        ' Interrupt definition
        INTCON=%10010000  ' Enable global interrupt
                          ' Enable INT0 interrupt (RB0)
        INTCON2.6=1       ' Enable INT0 on rising edge
        ON interrupt goto RB0_interrupt
        ' Variable definition
        Tmr2dutyvar VAR WORD
        DelayLoop   var word
        ' PWM signal generation
        Tmr2dutyvar=86 ' load duty time duration
        PR2=$57        ' load frequency period (PWM freq=3.6 KHZ)
            ' set Duty cycle
            CCP1CON.5=Tmr2dutyvar.1
            CCP1CON.4=Tmr2dutyvar.0
            CCPR1L =(tmr2dutyvar>>2)
            T2CON=%00000110 ' start timer 2
                            ' set prescaler = 16
            CCP1CON = %00001100 ' pwm mode for CCP1
        ' Main Loop
        ' Stupid led blink on PORTB.6...
    Start:
          toggle PORTB.6
          for delayloop = 1 to 50000
              pauseus 5
          next
          goto start
        ' Interrupt routine
        ' toggle PORTB.6 each rising edge on it.
    disable
    RB0_interrupt:
       toggle PORTB.7
       INTCON.1=0 ' reset INT0 interrupt flag
    resume
    enable
    By polling INT0 flag bit... no interrupt handler
        ' INT0 polling with PWM
        ' File name :  INT0_poll_PWM.bas
        ' Date : 02/03/2005
        ' We will check INTCON.1 (Interrupt on RB0(INT0) flag bit) pin to
        ' detect rising edge
        DEFINE OSC 20
        INTCON=%00010000  ' Disable global interrupts
        DelayLoop   var word
            ' set Duty cycle
        ' Main Loop
        ' Stupid led blink on PORTB.6 while testing INT0 flag bit
    Start:
          toggle PORTB.6
              pauseus 5
              if INTCON.1 then
                 INTCON.1=0
                 toggle PORTB.7
          next
          goto start
    TurboLS's Avatar
    TurboLS Guest
    Is there any reason why I can't get the process to start when PORTA.2 goes high?? I haven't rewired the HPWM/RB0 yet, but that should not matter. The PIC should at least shift the vertical clocks before even checking the reset (interrupt flag). Are my registers set correctly for analog input to PORTA.0 and digital input to PORTA.2??
    to have analog on PORTA.0
    ADCON1=%00001110
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  2. How do I set GPIO 0-2 and 5 simultaneously?
    By cstack in forum mel PIC BASIC Pro
    Last Post: - 19th August 2009, 09:32
  3. LCD will not start
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
