Triggering 5 TTL clocks simultaneously
Results 1 to 40 of 84
    TurboLS's Avatar
    TurboLS Guest
    And I set that in the registers, right? And then I can run a wire from PIN 17 to an interrupt pin and do an ON INTERRUPT command? Would it look something like this or totally different? I am going to try and find some examples.
    horizloop:
    ON INTERRUPT
    PORTB.2 = 0
    PORTB.3 = 1
    PAUSEUS 139
    PORTB.3 = 0
    PORTB.2 = 1
    PAUSEUS 50
    ADCIN 0, adval ' A/D 8 bit value from PORTA.0 into adval
    SEROUT2 PORTC.6,16416,[BIN8 adval,13,10] ' Output 8 bit word serially to PC from C.6
    PAUSE 87
    horizpulse = horizpulse + 1
    IF horizpulse < 784
    NOP...
    i'll have more spare time tomorrow for that... BUT have a look on this thread download the code i did. It use the interrupt on an pin to do specific task. Can be handy to start. Code is well documented.
    ON INTERRUPT GOTO define the place to go when an intterupt happen. See PBP manual on that statement. care will have to be made in the interrupt routine too. sould not be too loang... at minimum less than the time between each interrupts.
    TurboLS's Avatar
    TurboLS Guest
    Well I would think I would only need one in the loop, just to make sure the Reset(HWPM) and Horizontal 2 are on their rising edge as in synch as possible.
    TurboLS's Avatar
    TurboLS Guest
    What if I did something like this??
    horizloop:
    PORTB.2 = 0
    PORTB.3 = 1
    PAUSEUS 139
    ENABLE
    ON INTERRUPT GOTO H2lock
    DISABLE
    PAUSEUS 15
    PAUSEUS 87
    IF horizpulse < 784 THEN
    GOTO horizloop
    PAUSEUS 270
    GOTO vertloop
    H2lock:
    PORTB.3 = 0
    PORTB.2 = 1
    RESUME
    NOP, On Interruot goto is placed at the header of your code before your main loop. Since it's working in background, it will jump by himself to the interrupt routine. did you look at my previous link?
    INTCON and probably others have to be set for interrupt type/source.
    i'll make something like this later today.
    TurboLS's Avatar
    TurboLS Guest
    What do you think of something like this>?
    ' Connect analog input to (RA0)
    ' Connect clocks to PORTB
    ' PORTB.0 is the Vphase1 clock
    ' PORTB.1 is the Vphase2 clock
    ' PORTB.2 is the Hphase1 clock
    ' PORTB.3 is the Hphase2 clock
    ' PORTB.4 is the reset clock
    ' Connect pin 2 from the DB9 connector to PORTC.6
    ' Have a +5V source ready to touch PORTA.2 to trigger clocking process
    include "modedefs.bas"
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    DEFINE OSC 20 ' Sets clock speed to 20Mhz
    Define ADC_CLOCK 4 ' Set clock source (3=rc)
    ON INTERRUPT GOTO H2lock ' When Reset clock is high
    INTCON1 = %1001000 ' Enable RB0 Interrupt
    INTCON = $80 ' Disables Interrupts
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00001101 ' Set PORTA analog, except for pin 2
    TRISB = %00000000 ' Set PORTB to all output
    Pause 500 ' Wait .5 second
    horizpulse var byte
    vertpulse var byte
    adval var byte ' Create adval to store result
    horizpulse = 1 ' Initialize counters, initial states
    vertpulse = 1
    PORTB.0 = 0
    PORTB.1 = 0
    PORTB.2 = 1
    PORTB.3 = 0
    PORTB.4 = 0
    buttonloop:
    IF PORTA.2 = 1 then
    GOTO vertloop
    GOTO buttonloop ' Waits for 5V that signals shutter is closed
    vertloop:
    horizpulse = 1
    PORTB.0 = 1
    PAUSEUS 139
    PORTB.0 = 0
    PORTB.1 = 1
    PAUSEUS 139
    PORTB.0 = 1
    PORTB.1 = 0
    PAUSEUS 139
    PORTB.0 = 0
    PAUSEUS 270
    vertpulse = vertpulse + 1
    IF vertpulse < 512 THEN
    GOTO horizloop
    GOTO buttonloop
    horizloop:
    PORTB.2 = 0
    PORTB.3 = 1
    PAUSEUS 139
    INTCON = $80 ' Re-enables interrupts
    PAUSEUS 15
    PAUSEUS 87
    GOTO horizloop
    PAUSEUS 270
    GOTO vertloop
    DISABLE
    H2lock:
    PORTB.3 = 0
    PORTB.2 = 1
    RESUME
    ENABLE
    TurboLS's Avatar
    TurboLS Guest
    Also, I saw a blurb in the PBP manual about the fact that I can check the interrupt flag without actually enabling interrupts. If I did it that way, then I could merely do a check condition statement, similar to this, right?:
    IF PORTB.2 = 1 AND INTERRUPTFLAG = 1 ' When horizontal 1 is high and reset is high
    ' Do the H1 > low, H2 > high, ADC conversion and the SEROUT2
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. How do I set GPIO 0-2 and 5 simultaneously?
    By cstack in forum mel PIC BASIC Pro
    Last Post: - 19th August 2009, 10:32
  3. LCD will not start
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
