Triggering 5 TTL clocks simultaneously
Results 1 to 40 of 84
    1.) Is there a way to split PORTA into analog and digital inputs?
    for sure... see datasheet in the A/D section.. ADCON1 TABLE 19-2
    will be interesting to have kind of flowchart and schematic for the other problems you have.
    TurboLS,
    What version of PBP are you using? I've never seen this work in any versions I've had.
    IF vertpulse < 512
    THEN GOTO horizloop
    ELSE GOTO buttonloop
    I've wanted to use that type of syntax before, but I get nothing but errors. Did I miss an update or something. I have 2.45
    Darrel
    TurboLS's Avatar
    TurboLS Guest
    I am using 2.46 and I will have a pic up soon that has the timing scheme. thanks for the replies.
    TurboLS's Avatar
    TurboLS Guest
    here is the timing diagram. notice how the reset, H1, and H2 are in synch at the lower right. Also notice that the reset is going all the time, even when the other 4 clocks are not.
    please click the link and scroll to page 13
    http://www.kodak.com/global/plugins/...2ELongSpec.pdf
    thanks.
    TurboLS's Avatar
    TurboLS Guest
    Oh yeah, i am gettin some errors from that if else stuff too.... gonna have to find a way around that arghhhh!
    scratch that, you just have to put all the commands on the same line, like so:
    IF vertpulse < 512 THEN GOTO horizloop ELSE GOTO buttonloop
    however, i still have 9 errors to fix before mine compiles properly.
    TurboLS's Avatar
    TurboLS Guest
    Also, I tried looking at the ADCON1 register, and i guess if I am reading from the table properly... to set PORTA.2 to digital in, I should say ADCON1 = %00001101 cuz that's where the D and the AN2 meet.
    I am still having a problem with the OnPushButton command and apparently I have to use END IF commands, which I am not sure how I will implement just yet.
    TurboLS's Avatar
    TurboLS Guest
    I got it down to 6 errors, all with my IF statements. Here is what I have for a generic IF line:
    IF PushButtonOnPORTABIT2 = 1 THEN GOTO vertloop ELSE GOTO buttonloop
    on the following line i have
    and doing that got rid of 3 of the errors, but now I need to figure out why it doesn't like my then goto / else goto commands.
    For each of my 3 if statements, I get
    bad expression
    bad expression or missing then
    I prefer like this
        GOTO horizloop
        GOTO buttonloop
    Using Alias to i/o
    TRISA = 255 ' Set PORTA as input
    PushButton1 var PORTA.0
    PushButton2 var PORTA.1
    PushButton3 var PORTA.2
    IF PushButton1 then ' Same as PushButton=1
       ' do your stuff here
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. How do I set GPIO 0-2 and 5 simultaneously?
    By cstack in forum mel PIC BASIC Pro
    Last Post: - 19th August 2009, 10:32
  3. LCD will not start
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
