Triggering 5 TTL clocks simultaneously
Results 1 to 40 of 84
Threaded View
  1. #5
    TurboLS's Avatar
    TurboLS Guest
    Ok, here is my updated code, now I just have a few questions:
    1.) Is there a way to split PORTA into analog and digital inputs?
    2.) PORTB.4 is the reset clock and basically it has to be pulsing as soon as the microcontroller powers up. The problem is that once i start the other clocks, the time at which the reset goes high has to be in synch with H1 going low and H2 going high. In addition, it's high duration is 1/4 of the high time of the horizontal clocks. I will post up a timing diagram to explain what i mean later today. So basically I can't just put it in one of my loops, I have to start it pulsing at like a 25% duty cycle and when the other clocks are going, it has to be in synch with the horiztonals like i said earlier.
    any help is appreciated.
    ' Connect analog input to (RA0)
    ' Connect clocks to PORTB
    ' PORTB.0 is the Vphase1 clock
    ' PORTB.1 is the Vphase2 clock
    ' PORTB.2 is the Hphase1 clock
    ' PORTB.3 is the Hphase2 clock
    ' PORTB.4 is the reset clock
    ' Connect pin 2 from the DB9 connector to PORTC.6
    ' Have a +5V source ready to touch PORTA.2 to trigger clocking process
    include "modedefs.bas"
    ' Define ADCIN parameters
    Define ADC_BITS 8 ' Set number of bits in result
    DEFINE OSC 20 ' Sets clock speed to 20Mhz
    Define ADC_CLOCK 4 ' Set clock source (3=rc)
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %00000010 ' Set PORTA analog
    TRISB = %00000000 ' Set PORTB to all output
    Pause 500 ' Wait .5 second
    horizpulse var byte
    vertpulse var byte
    adval var byte ' Create adval to store result
    horizpulse = 1 ' Initialize counters, initial states
    vertpulse = 1
    PORTB.0 = 0
    PORTB.1 = 0
    PORTB.2 = 1
    PORTB.3 = 0
    PORTB.4 = 0
    buttonloop:
    IF PushButtonOnPORTABIT2 = 1
    THEN GOTO vertloop ' Waits for 5V that signals shutter is closed
    ELSE GOTO buttonloop
    vertloop:
    horizpulse = 1
    PORTB.0 = 1
    PAUSEUS 139
    PORTB.0 = 0
    PORTB.1 = 1
    PAUSEUS 139
    PORTB.0 = 1
    PORTB.1 = 0
    PAUSEUS 139
    PORTB.0 = 0
    PAUSEUS 270
    vertpulse = vertpulse + 1
    IF vertpulse < 512
    THEN GOTO horizloop
    horizloop:
    PORTB.2 = 0
    PORTB.3 = 1
    PAUSEUS 139
    PORTB.3 = 0
    PORTB.2 = 1
    PAUSEUS 50
    ADCIN 0, adval ' A/D 8 bit value from PORTA.0 into adval
    SEROUT2 PORTC.6,16416,[BIN8 adval,13,10] ' Output 8 bit word serially to PC from C.6
    PAUSE 87
    horizpulse = horizpulse + 1
    IF horizpulse < 784
    THEN GOTO horizloop
    ELSE GOTO vertloop
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  2. How do I set GPIO 0-2 and 5 simultaneously?
    By cstack in forum mel PIC BASIC Pro
    Last Post: - 19th August 2009, 09:32
  3. LCD will not start
  4. Replies: 11
    Last Post: - 13th July 2005, 19:26
