adcin trouble
Results 1 to 3 of 3
Thread: adcin trouble
    Mar 2010
    Austin, TX
    Default adcin trouble
    I am experimenting with a servo tester to gain some experience with pic programming. Especially reading a pot, and a switch to control the servo output. The pic is a 16f683 and I can get it working and I can read the switch, but I have so far failed to get anything but 0 from the pot.
    The pot input is pin 6, AN1 and I have verified that it varies the voltage from 0 to +5.
    Here is the relavent portion of code:
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC SAMPLES 50
    TRISIO = %11111110 ' set porta.0 output and all other to inputs
    ANSEL = %00000010 ' porta.1 to analog, others to digital
    ADCON0 = %10001001 ' analog input on porta.1, Right justify result
    CMCON0 = %00000111 ' Turn of the comparators
    PORTA = %00000000 ' set porta to all 0's
    pulse_width var word
    adcin porta.1, pulse_width
    Any help would be appreciated.
    Mike
    I will assume you mean 12F683 ?
    There is not a PORTA.
    TRISIO = %11111110 ' set GPIO.0 output and all other to inputs
    ADCON0 = %00000100 ' analog input on GPIO.1, Left justify result for 8 bit
    GPIO = %00000000 ' set porta to all 0's
    adcin 1, pulse_width
    Give it a try.. No guarantees...
    Mar 2010
    Austin, TX
    Thanks MACKRACKIT.
    You were right on both counts.
    Next is timer control and then interrupts.
    Thanks for the help.
