ADC multiplex with 4051
Results 1 to 8 of 8
    Default ADC multiplex with 4051
    Hi
    I want to multiplex 2 ADC's (AN0 and AN1) I have 2 8 to 1 multiplexers
    (CD4051) infront of the ADC's
    S0,S1,S2 are on RC0-RC2
    Enable of Mux 1 on RC4
    Enable of mux 2 on RC3
    I have declared an array of 16 Words
    AD var word[16]
    How can I with a for next loop:
    Set the first 3 bits of portC and then read the ADC and write to the
    respectively AD.x Word varialble ? with mux 1 enabled
    After passing 8 cycles I need to change from Enable mux1 to Mux2
    and read the other 8 remaining AD.x variables ?
    any suggestions ?
    May 2007
    Use an inner and outer loop.
    for i = 1 to 2
      for j = 0 to 7
        PORTC = j+(i*8)  'PORTC4:3 selects the multiplexer
                         'PORTC2:0 selects the channel
        ' Read ADC here into AD[j+((i-1)*8)]
      next j
    next i
    Thank you
    I tried it with some led's on the I/O and it is counting nicely
    Then I added the ADC and have put a potmeter to AN0
    But the result following LCD_overview4 is showing nothing
    LCD_overview3 is showing the right value
    AD var word[16]
    adval0 Var Word
    READ_ADC:
    ADCIN 0, adval0
    for i = 1 to 2
    for j = 0 to 7
    pause 1
    ADCIN 0,AD[j+((i-1)*8)]
    pause 1
    next j
    next i
    lcd_overview3:
    Lcdout $fe, 1 ' Clear screen
    LCDOUT "AD0: ",DEC4 adval0
    lcd_overview4:
    LCDOUT "AD0: ",DEC4 AD.0," AD1: ",DEC4 ad.1," AD2: ",DEC4 ad.2," AD3: ",DEC4 ad.3
    LCDOUT $FE,$c0
    LCDOUT "AD4: ",DEC4 AD.4," AD5: ",DEC4 ad.5," AD6: ",DEC4 ad.6," AD7: ",DEC4 ad.7
    goto read_adc
    May 2007
    I'm guessing that you left out the square brackets for the array subscripts in the lcd_overview4 subroutine.
    May 2007
    After thinking a bit more, you should be able to use a single loop.
    for i = 8 to 23
      ADCIN 0, AD[i-8]
    next i
    Offcourse I forgot the brackets
    I made one error in my explanation
    the first mux is on AN0 the second one AN1
    so in the middle of the for nextloop i need to switch to ADCIN 1
    Your single loop for ADCin0 and 1 is not clear to me
    May 2008
    Italy
    rmteo has forgotten to set portC. Just add the red line and it will work. (I sugget you to use a small delay)
    for i = 8 to 23
    PortC = i
    Pause 1
      ADCIN 0, AD[i-8]
    next i
    Remember that as you have wired the system mux2 will start first (from 8 to 15) and then to follow mux1 will be activated (from 16 to 23). If you need them the other way around then swap the wiring of portC.3 & portC.4
    Al.
    May 2007
    Quote Originally Posted by RFsolution View Post
    Yes, I did leave out setting PORTC in my single loop example. If you are using AN0 and AN1, try this.
    for i = 8 to 23
      PORTC = i
      if i < 16 then
        ADCIN 0, AD[i-8]
        ADCIN 1, AD[i-8]
    next i
    You can also use a single analog input by tying the outputs (Z pin) of the muxes together to AN0 then the code is simplified to this. Insert appropriate delays in both cases.
    for i = 8 to 23
      PORTC = i
      ADCIN 0, AD[i-8]
    next i
