Bargraph and 2x40 LCD problem
Results 1 to 9 of 9
    Default Bargraph and 2x40 LCD problem
    Hi all
    I have the following problem using a seiko 2x40 LCD (4042)
    http://www.shopeio.com/inventory/pdf/SeikoChar.pdf
    I use a 16F876 and read AD0 and AD1 which I want to display on line 1 and 2
    followed by a bargraph
    All works ok if the COL position is not bigger than 15
    If I use 16 it erase the the text and the bargraph starts on 1st line 1st character
    anyidea ?
    lcd_main:
    Lcdout $fe, 1
    LCDOUT "Forw: ",dec4 fwd_pwr," Watt"
    pause 10
    ; syntax- BARgraph Value, Row, Col, Width, Range, Style
    @ BARgraph _fwd_pwr, 1, 15, 25, 1024, boxed ' OK
    ; @ BARgraph _fwd_pwr, 1, 16, 25, 1024, boxed ' not OK
    Try using a variable for the starting column and BAR width.
    COL  VAR BYTE
    Width VAR BYTE
    lcd_main:
    Lcdout $fe, 1
    pause 10
    COL = 16 : Width = 25
     @         BARgraph  _fwd_pwr,   1, _COL,_Width,   1024,  boxed  ' OK
    The routines use a "trick" method to determine if the parameters being passed are constants or variables.
    Anything less than 16 is assumed to be a constant, and anything over that is taken to be the address of a variable.
    If it went up to 40, it could mistake a variable as a constant.
    On anything wider than 16 chars, you should use a variable for Col and Width.
    hth,
    Thanks Mel
    This works great
    Oeps Darrel !!!
    Understandable.
    We do look alot alike.
    California, USA
    Default Rofl!!!
    Ohh, man... Don't do that to me!!!
    I had to go out to the shop and grab my spare keyboard. It'll take me forever to get all the beer spray out of the other one!
    Jeez, most of it came up through my nose... (mmmm, hoppy.)
    I always suspected that you and Melanie might be twins.
    steve
    malc-c's Avatar
    malc-c Guest
    Understandable.
    LOL - Darrel, Mel's gonna give you one hell of a slap for that !!
    That's brightened up one dull Saturday morning !
    Do a search on bargraph and you will be amazed.
