subroutine for picbasic
Results 1 to 5 of 5
    jojokatada's Avatar
    jojokatada Guest
    Default subroutine for picbasic
    hi i want to make a subroutine for checking the status of each bit of portb and set a high on corresponding to porta.
    here is the assembly code
    checking portb
    btfsc portb, 0
    bsf porta, 0
    btfsc portb, 1
    bsf porta, 1
    btfsc portb, 2
    bsf porta, 2
    btfsc portb, 3
    bsf porta, 3
    please help me to translate this code into picbasic pro
    appreciate for any help
    TurboLS's Avatar
    TurboLS Guest
    OK, let me get this straight. You want your program to do the following:
    check if portb.0 is high, if so set porta.0 high and so on?
    If that's the case, then it's pretty easy,
    IF PORTB.0 = 1
    THEN PORTA.0 = 1
    ELSE PORTA.0 = 0
    IF PORTB.1 = 1
    THEN PORTA.1 = 1
    ELSE PORTA.1 = 0
    IF PORTB.2 = 1
    THEN PORTA.2 = 1
    ELSE PORTA.2 = 0
    IF PORTB.3 = 1
    THEN PORTA.3 = 1
    ELSE PORTA.3 = 0
    That is the bulk of what I think you are trying to do. You will have to set the TRISB registers to outputs. In addition, I don't know how fast you would want these changes to occur, so I would see if you could get something like this up and running and check to see if the speed meets your requirements.
    more easy than if then stuff...
    TRISA=0    'output on all PORTA pin
    TRISB=255 'Input on all PORTB pin
    CheckingPORTA:
         PORTA=PORTB
    1 line do everything
    jojokatada's Avatar
    jojokatada Guest
    hi Turbols
    appreciate your help i am trying to use in pic16f877a by checking each bit and send a high to porta to activate a relay.
    MyInput  var Byte
    TestLoop var byte
    Start:
        MyInput = PORTA
        For testloop = 0 to 7
            PORTB.0[testloop]=Myinput.0[TestLoop] ' send the state of the bit to
                                                  ' the according PORTB bit
        next
        goto start
  1. Using "END" in a subroutine?
    Last Post: - 13th February 2010, 17:32
  2. Multiple RETURNS within a single subroutine
    Last Post: - 21st June 2009, 17:43
  3. Pulsin within subroutine
    By Wesley in forum mel PIC BASIC Pro
    Last Post: - 11th January 2009, 00:05
  4. subroutine with hserin
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 19th December 2007, 03:56
  5. Replies: 0
    Last Post: - 28th May 2004, 18:25
