Improved interrupt handling
Results 1 to 3 of 3
Threaded View
    Desterline's Avatar
    Desterline Guest
    Default Improved interrupt handling
    Seems they culd improve the way interrupts are handled.
    The latency of the ON INTERRUPT methodology is undesirable. The excelent code from Tim Box that stores all the complier internal variables, allowing for picBasic instructions in an assembler interrupt, improves this. However, a simple interrupt may not use all of those variables, so saving and restoring all of them is excessive. It seems the compiler could make an inteligent decision on which ones need saved and create the neccesary code.
    Or, the compiler could use duplicate macros when a function is called in an interrupt routine.
    Perhaps the best solution would be a configurable combination of these options. The reletive speeds and resource utilization of the potential solutions could be presented to the user, then the user could decide which one to go with.
    Anybody have any thoughs on that?
    -Denny
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
    Last Post: - 3rd June 2009, 03:35
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  5. USART interrupt not interrupting right
    By Morpheus in forum mel PIC BASIC Pro
    Last Post: - 6th March 2005, 02:07
