I am trying to create an array by using the new ARRAYWRITE statement in PBP version 2.6 to add received characters from an RS232 interface to the string until a linefeed character is received.
When I type arraywrite in my MCSPlus editor, it does not automatically convert to all caps as a reserved word, which led me to believe that I didn't have my MCSPlus editor set to find and use PBP version 2.6. However when I went to the Compile/Program Options in MCSPlus, version 2.6 was already set as the compiler.
Is there any reason why MCSPlus won't find version 2.6 when selected, thus preventing me from using ARRAYWRITE?
Here is my code.
;--- if you un-comment these, you must comment the ones in the .inc file--
ASM ; 16F887, 8mhz crystal
   __CONFIG    _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
   OSCCON = %01110000    ' Select internal oscillator at 8 MHz
Include "Modedefs.Bas"
INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
                            ' User must make sure the AllDigital.pbp file
                            ' is in same directory location as this source
                            ' code before compiling.
    'DEFINE SHOWDIGITAL 1    ' When uncommented will show analog settings
                            ' in Assembler Results window.
    ' A/D & Comparators disabled for digital ops
        ' All of these statements should be commented out when using the
        ' INCLUDE "AllDigital.pbp" statement to set digital ops.
            'ADCON1 = %00001111
            'CMCON = 7
DEFINE OSC 8
'Register Settings
    TRISA = 0               ' PortA connections are used for LCD interface
    TRISB = %00000000	    ' Set PORTB to outputs as test LEDs
    TRISC.0 = 0             ' PortC.0 is used for a Heartbeat LED
    TRISC.2 = 0             ' PortC.2 is used for the LCD R/W connection
    TRISC.6 = 1             ' EUSART control will automatically reconfigure
    TRISC.7 = 1             ' these pins from input to output as needed.
                      ' RCSTA.7 = SPEN = 1 for Serial port enabled (configures
                      ' RX/DT & TX/CK pins as serial port pins).
                      ' RCSTA.4 = CREN = 1 for Asynchronous Continuous Receive
                      ' Therefore RCSTA = %10010000 = 90h
DEFINE HSER_TXSTA 20h ' Enable transmit, 8-bit, Asynchronous mode
                      ' TXSTA.5 = TXEN = 1 for Transmit enabled
                      ' TXSTA.4 = SYNC = 0 for Asynchronous mode
                      ' TXSTA.2 = BRGH = 0 for High Speed Asynchronous Baud Rate
                      ' Therefore TXSTA = %00100000 = 20h
DEFINE HSER_SPBRG 51  ' 9600 Baud @ 8MHz, 0.16%, , 51 = 33h = %00110011
'SPBRGH = 0
BAUDCTL.3 = 1         ' Enable 16 bit baudrate generator
' Make sure that SW6.8 on the EasyPic6 is set to ON position before powerup.
' Make sure that SW7.1 & SW8.1 on EasyPic6 are set to ON before powerup.
' Initialize the display
    Pause 500       ' Wait for LCD to startup after power on
    GOSUB InitializeDisplay
    PORTB = 0               ' Turn off the LEDs
    HIGH PORTB.4            ' Blink the one Test LED as proof MCU is running
    PAUSE 500               ' at time of power up.
    LOW PORTB.4
' Declare variables
i      VAR Byte             ' Index for rcvd word array element
string VAR BYTE[8]          ' 8 element array containing received characters
X      VAR BYTE             ' Variable holds received character from RS232
i = 0
For i = 0 to 7
    string[i] = 0           ' Clear all elements in the string array
Next
Clr_display:
    LCDOUT $fe,1                ' Clear the LCD display
    LCDOUT $fe,$80              ' Move cursor to 1st line of LCD
mainloop:
    PORTC.0 = 1            ' Blink Heartbeat LED during mainloop
    hserin [x]
    'HSERIN [DEC X]
    PORTB.5 = 1            ' Turn on PortB.5 LED if this statement is executed
                           ' as a test of receiving a character
    If X <> $a Then       ' If X=linefeed, end of string reached..clear display
       arraywrite string[i],8,Clr_display,[x]
       LCDOUT $fe,$80+i,    ' Append character to 1st line display string
       i = i+1             ' Increment array element index
    Else
       LCDOUT $fe,1        ' Clear LCD display on receipt of line feed
       i = 0               ' Reset array element index
    Endif
    Pause 500              ' Wait .5 second
    PORTC.0 = 0
    HSEROUT [DEC X,$d,$a]  ' Loopback of received character + CR + LF
    PORTB.6 =1             ' Turn on PortB.6 LED if this statement is executed
                           ' as a test of HSEROUT having sent a character.
GOTO mainloop
