12C671 - GP3 problem
Results 1 to 37 of 37
Threaded View
  1. #26
    May 2008
    Italy
    With reference to your schematic, I am sure you have mistaken in drawing it, while the hardware is correctly wired, otherwise you will short the 12 Volts as soon as you connect it to the circuit. ( see the snap posted and compare it with your circuit)
    As far as the code is concerned, I would place a delay below the label send
    send:
    PAUSE 10
    if gpio.1=0 then
    serout ToTx,N2400,["G0"]
    Low ToTx
    pause 10
    Al.
