What exactly do you mean?PIC works fine when 5V supply is continues.
When I put 5V continues supply i.e. system already gets +ve & -Ve 5V and does not depend on button press for -Ve. Then lowering GP3 does result in serout data.
In other words, pic gets its 5V continues and all pins pulled high with 10K. Lowering any pin results in serout data.
___________________
WHY things get boring when they work just fine?
No, it is 5V only. i.e. +5V & 0V.
___________________
Hi, FC
Reading that , ... I think you didn't show or tell us everything :My circuit only gets power when any button is pressed.
OR the code shown only is a part of ...
OR you should show the Hardware side ...
no way for us to help further not knowing what you did and how you did it ...
Hi, I have attached the schematic and this is the complete code I have shown here. Hope to find a solution soon.
___________________
The way I read this, from the data sheet
Every time you press the GPIO.3 button the chip will go into a continuous reset.Most other registers are reset to a “reset
state” on Power-on Reset (POR), MCLR Reset, WDT
Reset, and MCLR Reset during SLEEP
The chip never gets to read the configuration to see that MCLR is turned off.
Comments:
1) - There are no smoothing capacitors either side of the regulator - what are you using to provide the 12v supply. If it's simply a bridge rectifier off a transformer then the supply will need smootthing.
2) - I assume the diodes are LEDS ? If so then you would be better off putting them in series with the resistors rather than in parallel.
3) - If they are not LEDS, then try removing them from the circuit, there may be some reverse bias or something causing the current to flow and possibly short out the supply ?
As Dave has mentioned - It does sound as if you are constantly resetting the chip before it configures itself.
