Quote Originally Posted by malc-c View Post
Not sure about the 12C chip, but on 12F series GPIO3 is the MCLR pin and what could be happening is by grounding this you are resetting the PIC - there is a way of disabling the reset function on the 12F series, so you might need to do the same on the 12C chip
Hi, I already have disabled the MCLR - (in Config). I also mentioned in the post above that PIC works fine when 5V supply is continues. Thanks
