12C671 - GP3 problem
Results 1 to 37 of 37
    Exclamation 12C671 - GP3 problem
    Hi, I am having problems with GP3 of my 12C671. I am trying to use it as an input along with others (GP0,1,2,...,4). MCLR is off. All are held high with 10K, but pressing GP3 low, does not result in PIC performing accordingly.
    Any ideas please as how I can use this pin properly? Thanks
    ___________________
    WHY things get boring when they work just fine?
    Does your config look something like this?
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF
    It is:
    __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ALL
    ___________________
    Wink
    Hi, Finance
    could we see your config and declare stubb ???
    better, whole PBP program if possible ?
    Many, many reasons possible .... and crystal ball saturated.
    DEFINE NO_CLRWDT
    Define OSCCAL_1K 1
    @ __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_ALL
    '// For PIC12C671
    include "modedefs.bas"
    '// Define variables
    ToTx VAR GPIO.0
    PAUSE 30
    '// OSCCAL=0
    TRISIO = %111110
    OPTION_REG = %10000000
    ToTx = 0
    INTCON=0
    ADCON0.0=0
    ADCON1=7
    send:
    if gpio.1=0 then
    serout ToTx,N2400,["G0"]
    Low ToTx
    pause 10
    if gpio.2=0 then
    serout ToTx,N2400,["G1"]
    Low ToTx
    pause 10
    if gpio.3=0 then
    serout ToTx,N2400,["G3"]
    Low ToTx
    pause 10
    if gpio.4=0 then
    serout ToTx,N2400,["G5"]
    Low ToTx
    pause 10
    goto send
    ___________________
    Question
    re,
    1) did you try a simple pin test ??? just to verify pin is still alive ???
    2) did you verify your 10k is Ok ??? ( logic 1 on pin when nothing done )
    Also, Did you try enabling the CLR Watchdog ??? ...
    Do all '671 react like this ???
