One works, one doesn't
Results 1 to 3 of 3
    Omaha, Nebraska USA
    Unhappy One works, one doesn't
    This, on a 12F683 and PBP 2.47, works fine:
    @ INT_ENABLE TMR1_INT                   ; Enable interrupt for timebase
            CYCLE=0 : FLASH=16 : FLASH2=9   ' Initial values for "idle" condition
            FOR INDEX=1 TO 525              ' Test for trigger status at startup
                HIGH SLED                   ' Indicator is high during the test
                IF TRIGR=0 THEN GOTO ESCAPE ' Trigger released exits the test
                PAUSE 10                    ' 10 ms X 525 iterations = 5 seconds
            NEXT INDEX
    ESCAPE: IF INDEX<2 THEN GOTO BFLAG      ' Trigger not pressed, no mode change;
            IF INDEX<525 THEN GOTO AFLAG    '  held less than 5 seconds, change mode
            MFLAG=1                         ' If trigger has remained high for 5 or
            GOTO NXTEST                     '  more seconds, set mode optional (1)
    AFLAG:  READ 255,MFLAG                  ' Get mode option flag from memory
            IF MFLAG=0 THEN WRITE 255,1     ' If mode default, select optional (1)
            IF MFLAG=1 THEN WRITE 255,0     ' If mode optional, restore default (0)
    BFLAG:  READ 255,MFLAG                  ' Get mode flag again in case it changed
    NXTEST: READ 254,PFLAG                  ' Get data protect flag from memory
            IF ACTIVE=0 THEN                ' If held down at power-up, toggle flag
                IF PFLAG=0 THEN WRITE 254,1 ' If data not protected, protect it (1)
                IF PFLAG=1 THEN WRITE 254,0 ' If data is protected, unprotect it (0)
                WHILE ACTIVE=0              ' Wait for the button to be released
                    ALED=1                  '  and hold activity indicator on
                    WEND                    '  before continuing
                PAUSE 105                   ' Pause ~100 ms
                ALED=0                      ' Reset activity indicator
            READ 254,PFLAG                  ' Get flag again in case it changed
    This essentially identical fragment, on a 16F88 and PBP 2.60, does not:
    @ INT_ENABLE TMR1_INT                    ; Enable the frame counter interrupt
            GOSUB STARTTIMER                 ' Start the frame counter
                                             '      CHECK MEMORY PROTECTION
            READ 254,PFLAG                   ' Get state of memory protection
            IF PFLAG=1 THEN GOTO NXTEST      ' If "on", skip mode select
                                             '      CHECK FOR "STRAPPED" INPUT
            FOR INDEXW=1 TO 500              ' Test for TRIGGER status at startup
                CTLIGHT=1 : ALIGHT2=1        ' Indicators are HIGH during the test
                IF TRIGGER=0 THEN GOTO ESCAPE     ' TRIGGER released exits the test
                PAUSE 10                     ' 10ms x 500 iterations = 5 seconds
                NEXT INDEXW                  '      CHECK FOR MODE CHANGE
    ESCAPE: CTLIGHT=0 : ALIGHT2=0            ' TRIGGER not on, no mode change; held
            IF INDEXW<2 THEN GOTO BFLAG      '  less than 5 seconds, change mode
            IF INDEXW<500 THEN GOTO AFLAG    ' If TRIGGER is HIGH for 5 or more
            MFLAG=1                          '  seconds, set mode to optional (1)
            GOTO NXTEST
                                             '      TOGGLE MODE
    AFLAG:  READ 255,MFLAG                   ' Get state of mode option
    BFLAG:  READ 255,MFLAG                   ' Get flag again in case it changed
                                             '      TOGGLE MEMORY PROTECTION
    NXTEST: READ 254,PFLAG                   ' Get state of memory protection
            IF ACTIVE1=0 THEN                ' If held down at power-up, toggle flag
                CTLIGHT=1
                IF PFLAG=1 THEN WRITE 254,0  ' If data protected, unprotect it (0)
                WHILE ACTIVE1=0              ' Wait for CHAN1 to be released and
                    ALIGHT1=1                '  hold CHAN1 on before continuing
                    WEND
                PAUSE 100
                ALIGHT1=0 : CTLIGHT=0        ' Reset the indicators
    Since they are each at the head of much longer programs, I don't want to create clutter.
    But it seems, no matter what, the FOR loop on the second never starts (the lights don't go on) and it continues with NXTEST--even when the preceding READ and IF are commented out! I've checked and rechecked so many times that I probably can't see the simple problem. I even used crude breakpoints (turn a LED on, pause 5 seconds, turn it off).
    NXTEST works as it should. Both EEPROM locations are specified as "0" with DATA statements early in each program. I've looked at the EEPROM and the correct values are plugged in, but the value at 255 never changes; the one at 254 does. I even tried using 253 instead of 255. No change.
    Am I going blind, or what?
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    Omaha, Nebraska USA
    Okay, fixed it myself.
    I added a PAUSE 10 as shown.
    But I surely do not know why the fix worked!
            PAUSE 10
    Russ
    Jan 2006
    Istanbul
    Hi Russ,
    For your EE location 255, I am guessing that your programmer does not read that location eventhough may be it is already there.
