ShiftOut. Using PIC as Slave device.
Results 1 to 5 of 5
    Apr 2006
    Default ShiftOut. Using PIC as Slave device.
    I not sure if this is possible, since I am confused about shiftout command.
    I would like to use the pic as a slave device. The pic would receive the clock signal from a master device, and the pic would shift out a byte.
    The master device sends the latch and clock data, the pic would receive that data and shift out a byte of serial data. Is this possible?
    Thanks for any help.
    TonyA
    I am not sure either... Never used the PIC as a slave.
    If the master device could send a signal to the PIC letting the PIC know data is ready then maybe the PIC could start a SHIFTIN ?
    What is the master device?
    Apr 2006
    Thanks. Well my problem is that I might not fully understand the shiftout command.
    The master is another microcontroller, the Atmega8. The Atmega is sending a clock signal and latch data, the pic (slave device) will receive the clock signal and latch data, and then send out a byte of data to the Atmega.
    So I'm guessing that I would just connect the clock output of the master (Atmega) to an input pin of the pic (slave) and that would be the clockpin of the command: shiftout dataOutpin, clockpin, (serial data)
    The latch output signal of the master (Atmega) would be received by an input pin of the pic (latchReceivePin), and I guess I would do something like this?
    If latchReceivePin = 1 then 'if the pic receives a "high" signal on its input pin then shift out a byte of data to the Atmega.
    shiftout, etc.
    I still don't know if I understand "shiftout" correctly, but I'll experiment with this today. If anyone can offer any advice or clues please let me know.
    Thanks again.
    Sep 2005
    Campbell, CA
    Something like this should work (untested). Note that is "blocking", and that the code will not advance past this until you get 8 high-to-low transitions on the clock.
    GetNextByte:
    BitCounter = 0
    GetNextBit:
      While ClockPin=1:Wend                 ; Sits here and does nothing while clock pin is high
        DataByt.0 = DataPin                 ; Samples data pin as soon as clock goes low
        BitCounter = BitCounter + 1         ; Keeps track of number of bits received
        If BitCounter = 8 then goto GotByte ; When we have a byte, get out
        DataByt = DataByt << 1              ; Move things over for next bit
      WHILE ClockPin=0:WEND                 ; Sit here while clock is low
        Goto GetNextBit                     ; Grab next bit if we haven't got all 8
    GotByte:
    Charles Linquist
    Apr 2006
    Thank you for the help and advice, I appreciate it.
    Tony A
  1. Watchdog Timers
    Last Post: - 27th August 2014, 19:03
  2. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  3. Smart Star (how to use shift registers)
    By mackrackit in forum Code Examples
    Last Post: - 30th November 2008, 21:06
  4. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  5. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
