More IF_THEN dumb questions.
Results 1 to 12 of 12
Threaded View
  1. #2
    For this Kind of task i'll prefer using Select Case instead of bang my head everywhere.
    I see you check only two bits variable..
    if r1sched = 0 and r1ctrl = 1 then
    if those are comming from some PORT pins, let's say PORTB.0 and PORTB.1 use the following
    GetPORTB = PORTB & $3 ' mask other bits than B0 and B1
    select case GetPORTB
          Case 0 ' b0=0 b1=0
            ' Do your stuff here for that condition
          Case 1 ' b0=1 b1=0
          Case 2 'b0=0 b1=1
          Case 3 ' b0=1 b1=1
    end select
    that's easier like that.
    Or you can also use BRANCH statement that will make your program jump (GOTO) to a specific label depending of the value of your var.
    branch GetPORTB[condition0,condition1,condition2,condition3]
    BUT in case you still want to use IF then bla blah
    IF condition 1 then
        ' do your stuff here
    IF condition 2 then
    IF condition 3 then
    IF condition 3 then
  1. Olympic Timer
    Last Post: - 17th September 2008, 19:46
  2. Two quick (and elementary) questions.
    By scorpion990 in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 23:03
  3. A few 12F683 questions
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 03:54
  4. Usart Questions
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 8th March 2008, 01:17
  5. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 18:27
