SEcond wish is PIC codes Wizard
Results 1 to 12 of 12
    Quote Originally Posted by hardcore View Post
    Hi All,
    In practical applications easy to use analog /logic IC to build working devices.
    For automation purposes it is easy to use PLC they are cheap now.
    Unfortunately cost of PIC and developing hardware and software is high than when using IC.
    So my wish is PIC codes Wizard for cost of $50 that able to generate working codes or working program in easy and fast way.Generated program for choosen PIC will be ready to use after PIC programming .
    Next step is to improving program where beginners able to learn in faster way than now.
    Best wishes to All
    Actually you already have it. It's called the MANUAL and it comes FREE with every copy of PBP. By refering to the MANUAL you will "be able to generate working codes or working program in easy and fast way". I refer you to my reply to you fourth wish.
    Dec 2008
    New York US
    Lightbulb
    Hi Melanie,
    So I like your sense of humor about education.
    Lets me split it in two categories:
    1.Education taken for professional evaluation and learning about common knowledge.
    2.Professional experience in one field for long period of time to learn
    occupational Tip and Tricks.
    So I respect you knowledge in PIC programming.
    Sorry I did not explain what I mean in second wish:
    It is about Graphical PICBASIC PRO User Interface that let user to input by drag and drop impulses on real time flowchart with needed resolution to output, impulses on input lines, enable interrupt processing by pointing in spots on chosen real-time flowchart.
    After that PICBASIC Pro have to generate pbp, bas, asm, and hex files.
    A graphical user interface will allows people to interact with programs in more ways than typing statement by statement and uses visual feedback to the user as much as possible.
    So after all it is my expectation for future development of PICBASIC PRO that let us:
    •Easy to Learn
    •Easy to remember how to Use
    •Effective to Use
    •Efficient to Use
    •Safe to Use
    •Enjoyable To Use
    If we able see 3-5 years ahead so it is high probability that Graphic interfaces will be implemented in wide range of software spectrum.
    Try to make patent search for last years and you will see that a graphical user interface
    is reality Want we it or NOT.
    Better to be prepared.
    Best Regards to All
    Default What part of my previous post was unclear?
    Hardcore - I already posted that this exists, in this thread...
    http://www.matrixmultimedia.com/Flowcode3a-X.php
    I don't get it...
    Dec 2008
    New York US
    Smile
    Hi mtripoli,
    Big thanks for your link.
    Needs time to look in subject so definitely I will do it.
    Right now I have few PIC16F84A, PICF628, PIC16F88 and need to find solution how to use them for my applications.Had mistake and bought them to learn about possible usage.
    Later ideas of my projects comes up.
    It is like unfinished job and I want to finish it before switch vector to other
    hardware.
    Thanks for any ideas.
    Best Regards
