I think Elektor raised a cheap PLC project ... some years ago.
Soft, and all goodies still available from the editor's site ...
pic basic has similar structures to PHP...
But more importantly, it's BASIC, Beginners All-purpose Symbolic Instruction Code... As it was was used on spectrum's, commodore's and amega's etc back in the 80's...
The only way you can get simpler is to use a GUI with flow diagram style utility...
However, the question is, the easier you make something to use the more numptys you get trying to do stupid things and blowing themselves up...
Or worse, giving a terrorist the capability to create a GPS guided smart bomb/missile!
IMHO, if you can't figure out how to use BASIC then you should not be trying to do it...
There is in fact a graphical programming package available for the PIC. It's from MatrixMultimedia: http://www.matrixmultimedia.com/Flowcode3a-X.php
I looked at the demo and it seems kind of neat. The "idea" is there and the tool looks robust. It is not a panacea; it still requires that you understand what it is that you are doing and can "fill-in" the correct information in the right places. I've seen similiar dedicated packages for audio DSP's and such that used a graphical environment for drag-n-drop of modules to create an application. Though I respect what they are doing (call me a snob) I think the graphical aspect of the overall package is kind of ugly...
I've been recently using Labview (not for PIC's; for doing optical recognition on a new manufacturing machine we're designing at "work"). This has come a long way with the drag-n-drop graphical programming. Again however, you can't be a "numpty" using it
Mike Tripoli
Hi All,
Thank you for very useful advices, links.
Problem is that each software has limitations so PICBSIC Pro included.
After years in engineering fields simple blink and dice programs does not help
to solve problems with own projects because of complicity.
For time frames from one to 10mSec many PICBASIC PRO statements works well.
If I am trying go to tenth uSEc time frames I have to go to use assembler.
I bought two PIC kits such as LC meter and 50Mhz frequency counter and after testing
I found that better to try learn and continue experimencing with PICs and PIC software.
Here is below attached draw picture that explain one part of my PIC project I want to continue with PICBASIC PRO or to use assembler statements.
Right now I am on crossroads where one road is PICBASIC PRO second one is assembler third one is PIC itself and the last one is do something else.
Because I am not working as software developer I am asking
for your advice where I can start with my project:
Is it possible to get 1 sample of analog signal and transform
to 8bit sample by PIC in 500nSec period of time?
What kind PIC can I use (with internal 8 bit ADC or external)?
How to store and where (RAM or Registry) 1 samples of 8bit data
in such short period of time-500nSec or 10 samples in total period of time 500uSec?
Where can I find time chart for each statement in PICBASIC PRO or assembler?
If this disscusion on Wish section is not match so we can move to PIC codes section as well.Any practical ideas appreciate.
Best Regards to All![]()
Hi, Hardcore
I Think you are dreaming too much ...
take a 18F2xK20 @ 64 Mhz ...
makes 63 ns per instruction ...
How do you think to be able to sample ( and at least store !!! ) your values having 8 " asm commands " available ??? ( sampling time not included ... see datasheet !!! )
just take a recent 8 bits Pic, and write your .asm code just for 1 sample ... how long ???
you have to jump to much more powerful devices ... that's all !!!
It's not a PicBasic Problem .... as even asm coding can't allow it !!!
Hi Alain,
Just want to solve the puzzle.
So PIC and PICBASIC PRO or Assembler do not helpful in present case.
Main point of solving the problem is to make 8 bit ADC external.
So 8bit equal 256. Single cycle of conversation is 500nSec / 256 is equal 1.95 nSEC.
Crystal clock has to be 512 MHz then divided by ~25 will get 20Mhz that will feed PIC.
From this point of you are right and I agree with you.
If we decide to take 4bits ADC conversations or 16 steps 500nSec/16 is equal 32 MHz.
It is close to final.
If external ADC has build in comparator and RC circuit conversations can be done in 200nSec.External clock is 80 MHz.
So we have extra 300nSec + 500nSec is equal 800nSEc that means we can use
four instruction for reading from 4bits PORT and storing in external 4bits PORT storage like RAM data by 40Mhz PIC16F.
Where am I wrong?
Best Regards
