Help, PBPL and DIV 32.
Results 1 to 8 of 8
    Use LONG variables.
    Then you can go up to ...
    LCDOUT  DEC10 MyLong
    or simply DEC will display however many digits there are.
    Feb 2010
    I was using Long variables but trying to display with #Variable, thought it was the same as DEC. Working great now.
    Thanks again Darrel!
    Rogerio
    Wink
    Hi, Darrel
    While you're here ...
    A question I have for long time ... linked to the subject.
    Is it possible to do something like conditionnal assembly with PBP ??? never saw anything about that ...
    and Google doesn't return anything nor ...
    At the PBP level ... NO.
    At the ASM level ... YES.
    In other words, you can not conditionally compile variables, array sizes or anything that PBP needs to know before passing it on to the assembler.
    Once it's at the assembler, you can conditionally remove any part of the PBP "Code" that you wish.
    But only the code.
    Not the variables, defines or any variables/defines in other include files.
    All you do is put if/endif's around what you want or don't want...
    DEFINE MyOption 1
    @  if (MyOption == 1)
        LCDOUT "Option 1 HardCoded"
    @  endif
    Re,
    Ok, that's more than nice to me ....
    just looked for " embedding " PBP commands ...
    Thanks, Darrel
