PBP v2.50a Vs 2.60 and USB compile errors
Results 1 to 11 of 11
    Wink
    Hi, Darrel
    I tried to update my "USBdemo" as stated in the first link you provide ...
    BUT got:
    C:\PROGRAM FILES\MICROCHIP\MPLAB IDE\PROJETS\USBDEMODESC.BAS ERROR Line 7: Bad BANK number.Halting build on first failure as requested.
    BUILD FAILED: Thu Mar 18 09:15:16 2010
    and line 7 is :
    USBReservedMemory Var Byte[USBMEMORYSIZE] USBMEMORYADDRESS	' Reserve memory used by USB assembler code
    that sends us to
    USBMEMORYSIZE	Con	256	' USB RAM size in bytes
    and
            include "PBPPIC18.RAM"
    USBMEMORYADDRESS Con	$400	' USB RAM starts here
    resulting in that I do not see what's wrong ...
    Dong, Dong, Dong, Dong ....
    PS: PBP2.60 + MPLAB 8.46
    Which all seems good for an 18F2455/2550/4455/4550 series.
    Some of the newer chips use $200 for the USBMEMORYADDRESS.
    But that's taken care of automatically.
    Which PIC are you using?
    I use a 4550, the one I used for the original Demo ...
    Is that the only error you get?
    I suspect there may be another error before that one?
    Halas no ...
    it is the only error reported ...
    I don't know Ace.
    But since I've already duplicated it for others, I know it works.
    Your actual code might reveal something one of us missed.
    Just zip the whole folder.
    Ummm, Do you still have the 18F4550.bas or .bal file from the old program leftover in your project folder.
    You should not. It will override the files in the PBP folder.
    Mar 2010
    Default Success - thanks
    Thanks DT that cleared my errors and I can compile under 2.60 !!
    Is there anything else I have to do to optimize for 4550?
    Under 2.50a code was 28,785bytes but under 2.60 it has increased to 29,309.
