Thankyou Ioannis; i have tried to change the baud rates but still no response.
regards
dumato
regards
dumato
Usually the baud is at 9600 by default.
Also USB to Serial converters may pose an issue sometimes.
When i compile my code i generate HEX file of 3KB which cant fit PIC16F84, since its limit is 1KB is there a way i can compress it and load it into pic16f84
regards
Thankyou Ioannis, Now the only choice is to change pic but i will have to just to simulate it bse i had only pic16f84, but wen i changed to pic16f877 and tried to simulate, nothing appeared on virtual terminal and proteus gave me this message ''can't perform real time simulation due CPU overlaod, what should i do?
regards
dumato
I never use simulators of any kind. And Never ever write the whole program at once. I am not Darrel or Melanie...
What I do is:
1. Whenever I change PIC, I start by a led and a button. Just 3 lines of code to read the button and light the LED.
2. Then I add a serial port to see on a terminal what is happening to the PIC.
3. Then an LCD and see if it works.
4. Then...
Thankyou Ioannis, am going to do that
regards
dumato
