PLIZ CHECK MY SCHEMATIC,pic16f84->max232->gsm phone
Results 1 to 39 of 39
    It does support the full AT commands from Nokia. you have to find that AT command manual though.
    You will also need a specific cable from Nokia to RS-232.
    Mar 2010
    Default phone interface
    I have found that i can use DLR3 cable, trying to look for and test
    regards
    dumato
    Mar 2010
    Default Hyperterminal
    When i connnect the phone to the PC and test the cable with hyperterminal, there is no response thats no ERROR or OK, what could be the problem,
    I used the following commands at the hyperterminal,
    AT
    I expected OK or ERROR but its blank
    AT+CPIN?
    I expected +CPIN? READY OR ERROR but blank also
    Could it be the cable?, PC or settings of PC, pliz guide me.
    regards
    dumato
    A million reasons!
    Maybe the baud rate?
    Mar 2010
    Default hyperteminal
    Thankyou Ioannis; i have tried to change the baud rates but still no response.
    regards
    dumato
    Usually the baud is at 9600 by default.
    Also USB to Serial converters may pose an issue sometimes.
    Mar 2010
    Default size of hex file
    When i compile my code i generate HEX file of 3KB which cant fit PIC16F84, since its limit is 1KB is there a way i can compress it and load it into pic16f84
    regards
