PLIZ CHECK MY SCHEMATIC,pic16f84->max232->gsm phone
Results 1 to 39 of 39
    Mar 2010
    Default PLIZ CHECK MY SCHEMATIC,pic16f84->max232->gsm phone
    Hullo friends
    Pliz check my schematic attached whether the connections are ok and guide me, the pic16f84 should instruct the phone to send SMS when push button is +5V, which phone do u suggest i use, help me with coding and any other advice,
    thankyou
    regards
    dumato
    Post your code please.
    Hmm, wth no phone there is no help though.
    You have to select a phone with Serial port like the old 6210, 6310 of Nokia with the appropriate serial cable. But nowadays I think it is a little difficult to find such a device.
    May be you have to find a GSM module from an on-line shop (e-bay, sparkfun, digikey, etc)
    Once I used the Wavecom and have to same they are very good.
    About examples look at http://www.picbasic.co.uk/forum/showthread.php?t=3765
    There is code available but for specific model.
    Feb 2003
    You may want to connect Pin 5 of J1 to ground
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mar 2010
    Default sample code
    Thankyou for ur contributions, about the code, am totally new in Picbasic programming but i got some code from the forum and tried to make it suit my project, it returns sucess when its pic616f877 what changes and additions should i make for it to suit pic16f84
    code:
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    'Setup the names that will be used throughout the program
    PushButton var PORTB.0 ' Setup the name PushButton to mean PortB input 0
    IF PushButton = 0 THEN SMS 'If button is pressed then run the SMS routine below
    goto main ' however if the button is not pushed then just go back to the Main
    ' routine to wait for the button to be pressed
    SMS: ' this is the SMS commands routine in order to send an SMS
    HSEROUT ["AT" ,13,10] ' send AT to modem followed by a CR and line feed
    HSERIN 5000, SMS, [WAIT("OK")] ' now wait for 5secs until OK is received however
    ' if it is not then goto the SMS routine again
    HSEROUT ["AT+CMGF=1" ,13,10]
    HSEROUT ["AT+CMGS=+256782277658"]
    HSEROUT [13,10]
    HSERIN 5000, SMS, [WAIT(">")]
    HSEROUT ["BUTTON HAS BEEN PRESSED!"]
    HSEROUT [26] ' this is ASCII for Ctrl+Z of which completes SMS sending
    HSERIN 15000, SMS, [WAIT("+CMG")] ' then PIC should receive +CMG from modem
    HSEROUT [10] 'ascii code for a line feed
    Pliz help me
    regards
    dumato
    1. Get rid off 16F84. It does not have Hardware Serial Port. It is old. It is too expensive too. From direct.microchip.com you can order whatever you want at very low cost.
    2. If you insist on using the F84 part, you have to change the commands from HSERIN/HSEROUT to SERIN/SEROUT or SERIN2/SEROUT2 as these are the software commands. Read the Manual for these. Almost the same as the hardware ones.
    But I really do recommend to use other chip.
    Mar 2010
    Default pic16f84
    Thankyou Ioannis, currently its pic16f84 available for my project and in my country its hard to get access to microcontrollers so i have to just utilize it.
    I have replaced HSERIN/HSEROUT with SERIN/SEROUT but still generating errors,probably i have change something again;
    After changing this is the code:
    SEROUT [13,10]
    regards
    dumato
    Feb 2003
    The defines you have that start with "HSER" are for a harware serial port which the F84 doesnt have therefore the compiler will not be happy with you trying to define a non existant value.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Please READ the manual about the Syntax of the Commands.
    You do not define the port pin, the baud rate. No wait for Serin (only for Serin2). No square brackets for the variables. Only in Serin2.
    Same for the Serout/Serout2.
    And as keithdoxey noted, no DEFINEs as these are for he Hserin/Hserout.
    I do not like the "read he manual" statement but I cannot teach you the Lanquage and how to write programs. It is something you have to do it yourself.
    Do you have a printed manual?
    Start by flashing a LED, as trivial may sound this.
    I even do this when I change PIC micro, just to be sure that I am in control of the new beast before I try anything more complicate.
    Mar 2010
    Thankyou keith and Ioannis for ur contributions, pliz help me with the link for the manual and i try to follow it up. I dont have hard copy, mean while i wil make the changes u have told me
    regards
    How about obtain a legal copy of the PBP compiler?
    Feb 2003
    Quote Originally Posted by dumato52 View Post
    Help terminated !!!!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mar 2010
    I read through the manual and made the changes, now the new code is succesful with 16f84 but i wanted the same message to be sent to two phone numbers, pliz help me and check the code below;
    code:
    SEROUT PORTB.1,6,["AT" ,13,10] ' send AT to phone followed by a CR and line feed
    SERIN PORTB.2,6,["OK"] ' now wait until OK is received
    SEROUT PORTB.1,6,["AT+CMGF=1" ,13,10]
    SEROUT PORTB.1,6,["AT+CMGS=+256782277658"]
    SEROUT PORTB.1,6,[13,10]
    SERIN PORTB.2,6,[">"]
    SEROUT PORTB.1,6,["BUTTON HAS BEEN PRESSED!"]
    SEROUT PORTB.1,6,[26] ' this is ASCII for Ctrl+Z of which completes SMS sending
    SERIN PORTB.2,6,["+CMG"] ' then PIC should receive +CMG from modem
    SEROUT PORTB.1,6,[10] 'ascii code for a line feed
    regards
    Something like this?
    '---------- second number------------
    SEROUT PORTB.1,6,["AT+CMGS=+000222333666444"]
    Mar 2010
    Default phone interface
    Thank you Ioannis, i highly appreciate ur help;
    Now i need to connect the phone to microcontroller, am looking for the models u told me nokia 6210, 6310 but i needed to know when i acquire the phone, how do i test whether it supports AT commands, any software i need to instal?
    regards
    dumato
    I would recommend to find a GSM module or a device like the Wavecom, Siemens or other brand. All support AT commands.
    Mobile phones are not designed for this job, although they will work eventually.
    May 2008
    Italy
    Ioannis, I would stress your above recommendation adding that some old phone will accept AT command, but they will work only in PDU mode, while the OP needs to work in Text mode.
    Al.
    Hi Al.
    Your project related to GSM remote control has been down. Are you aware of it?
    May 2008
    Italy
    .... Are you aware of it?
    Yes! I will upload it in the new forum as soon as I understand how does it work.
    Al.
    Mar 2010
    Thankyou for ur advice on GSM module but i think i can easily get 6210/6310 nokia in my country, how do i test whether it supports AT commands?, will it be affected by the baud rate i set at 9600?
    It does support the full AT commands from Nokia. you have to find that AT command manual though.
    You will also need a specific cable from Nokia to RS-232.
    Mar 2010
    I have found that i can use DLR3 cable, trying to look for and test
    regards
    dumato
    Mar 2010
    Default Hyperterminal
    When i connnect the phone to the PC and test the cable with hyperterminal, there is no response thats no ERROR or OK, what could be the problem,
    I used the following commands at the hyperterminal,
    AT
    I expected OK or ERROR but its blank
    AT+CPIN?
    I expected +CPIN? READY OR ERROR but blank also
    Could it be the cable?, PC or settings of PC, pliz guide me.
    regards
    dumato
    A million reasons!
    Maybe the baud rate?
    Mar 2010
    Default hyperteminal
    Thankyou Ioannis; i have tried to change the baud rates but still no response.
    regards
    dumato
    Usually the baud is at 9600 by default.
    Also USB to Serial converters may pose an issue sometimes.
    Mar 2010
    Default size of hex file
    When i compile my code i generate HEX file of 3KB which cant fit PIC16F84, since its limit is 1KB is there a way i can compress it and load it into pic16f84
    regards
    No!
    Mar 2010
    Default change of pic
    Thankyou Ioannis, Now the only choice is to change pic but i will have to just to simulate it bse i had only pic16f84, but wen i changed to pic16f877 and tried to simulate, nothing appeared on virtual terminal and proteus gave me this message ''can't perform real time simulation due CPU overlaod, what should i do?
    regards
    dumato
    I never use simulators of any kind. And Never ever write the whole program at once. I am not Darrel or Melanie...
    What I do is:
    1. Whenever I change PIC, I start by a led and a button. Just 3 lines of code to read the button and light the LED.
    2. Then I add a serial port to see on a terminal what is happening to the PIC.
    3. Then an LCD and see if it works.
    4. Then...
    Mar 2010
    Default simulation
    Thankyou Ioannis, am going to do that
    regards
    dumato
    Mar 2010
    Default simulation
    I have practiced simulation, now i was trying to simulate my project above but Virtual terminal is showing AT,AT, AT contineously after pressing ON the push button. What could be the problem?
    regards
    Well, my car is not moving... what might be the problem???
    Mar 2010
    Hullo Ioannis, probably u needed details,my code is below,am using pic16f877,
    code:
    DEFINE OSC 8
    SMS:
    HSEROUT [13,10]
    HSEROUT [26]
    HSEROUT [10]
    Your AT you see, is every 5 seconds, right?
    The Hserin command times out on 5000 msec because it does not receive any response, like an OK.
    I will repeat my self again now telling that simulation is not a panacea...
    cant help much with code but i am currently doing very much the same with a 2550, as i found the f84/f88 to be short of code space.
    the t68i will connect direct to a pic and is 5v tolerant, it works at 9600 and better at 4800, but 1200 gave best performance with 0 errors.
    the t68i only works in pdu mode, but you can make the pdu stings in pduspy, and then just cut/paste them into your code for sending.
    decoding is a little more tricky.... but you can cheat by reading your message in pdu and comparing it to what it should look like in pdu, you never need to use plain text, and should stop thinking of sms messages as messages and think of them as response strings, and as with all response strings, you compare them to what they should look like, its just as easy to compare 'ok' to 'ok' as it is to compare 32'65'66'67 to 32'65'66'67 as it is to ' ABC' - why waste time converting in chip, when you can convert before compile and just use the converted string.....
    good luck.
    and move to a bigger chip lol
    /comments on his SW status, he says he has no manual, not that he's a pirate, have you never lost a manual?
    and on my own point here, if he is a pirate, I'd sooner he was using PB and contributing to the group and not to some other group!
    flies/bees/honey/donkeys/carrots/sticks.....
    Mar 2010
    Default simulation
    Thankyou Ioannis and f Lez for your contributions, i got the point of no response from the virtual terminal, am wondering how can i make it respond, like when pic16f877 sends ''AT'' ,terminal is supposed to respond ''OK'',
    Do i need to use two virtual terminals? pliz guide me
    regards
    Mar 2010
    Default code
    Thankyou Ioannis, i have decided to remove the option for the response from the phone since i think that can only be achieved practically not through simulation, BUT, i have encountered one problem!, When the push button(interrupt) is detected the microcontroller sends a message contineously, how can i stop this?, I want it to send a message only once on detection of an interrupt, my code is below
    regards
    code:
    BEGIN:
    if PORTD.2 = 0 then SEND_SMS
    GOTO BEGIN
    SEND_SMS:
    sound PORTB.2,[100,10,50,10]
    HIGH PORTB.6
    HSEROUT ["at+cmgs=",34,"+256782277658",34,13]
    PAUSE 1000
    HSEROUT ["An interruption has occured",34,13]
    LOW PORTB.6
    HIGH PORTB.6
    HSEROUT ["at+cmgs=",34,"+256772021358",34,13]
    PAUSE 1000
    goto BEGIN
    Isn't it obvious? What are your code doing?
    1. Button pressed?
    2. Yes, goto send SMS
    3. Button pressed?
    4. Yes, goto send SMS
    5. .....
    You are in an endless loop.
    You may check if the button is released before sending another SMS.
    Or have a timer to send every say 10minutes if the button is still pressed.
    Or have a flag set in the sending SMS routine and cleared when the button is released
    Or...
