I2CREAD issues with 24FC512 EEPROM
Results 1 to 6 of 6
    Dec 2008
    Los Angeles, CA
    Not at all. It's just a curiosity, and a slight concern for the units already deployed. Lesson learned.
    Feb 2009
    Southern California
    I had a similar problem with the write command. DT said it had something to do with adding LONGs in 2.6. You can see his response here
    Maybe something similar happened with the I2CREAD command
    David
    I try to avoid doing Math in any I2CREAD or I2CWRITE statement. Do it first and keep the statements as clean as possible. Always do what the book says. It says use a particular kind of variable, then use a particular kind of variable. It doesn't say Math is allowed, and doesn't show you examples with Math - so don't do it.
    You DON'T need PAUSEs for READING - you can do that at top speed. You DO need them for writing - the EEPROM Datasheet will tell you how much is required.
    Dec 2008
    Los Angeles, CA
    Thumbs up
    Thanks Luckyborg. Think DT answered the question, and will keep an eye on patches to 2.60.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
