Quote Originally Posted by RussMartin View Post
I'm going to be working with the SRF02. I'd be interested in knowing what you developed. I assume it was I2C and not serial?
I am attaching a routine I use as an Interrupt Service handler with Darrel Taylor's DT_INTS-18.bas. Whenever the interrupt is received it executes this routine to take an ultrasonic range measurement, display it to LCD, and log it to EEPROM.
Note that I am using an I/O pin from the MCU to turn on and off power to the SRF02. Whenever the SRF02 is turned off but still connected to the I2C bus it will distort the bus and prevent use of any other devices that are connected to I2C. Therefore, just before and after you want to use the I2C bus for any device, you will have to turn on or off the SRF02. I did this to save battery power so I didn't have to keep the SRF02 continuously powered up.
Hope this works for you.
Range:
    HIGH ext_pwr ' Temporarily turn on power to SRF02 for I2C bus use
    PAUSE 500    ' Delay to let I2C bus stabilize after SRF02 turn on
    'DEFINE WRITE_USED 1 'Required if only writing WORD variables in v2.6
    ' Update day counter and address offset for day's measurements
        READ 9,day_cnt        ' Test if EEPROM data has been captured
                              ' & cleared by PC & new monthly epoch
                              ' started.
        day_cnt = day_cnt + 1  ' Increment day counter
        Write 9,day_cnt 'Update contents of day_count memory address
        Pause 10
        If J >= 240 Then
           J = 0    ' If allocated EEPROM already used, start over
    ' Make SRF02 Range Measurement
        I2CWRITE SDA,SCL,$E0,0,[80]  ' Request start of ranging in inches
        pause 100                    ' Wait for ranging to finish
        I2CREAD SDA,SCL,$E0,2,[rng1,rng0] ' Get ranging results
        'WRITE 253,rng1
        'Write 254,rng0
        WRITE 240,Word w0            ' Write range to EEPROM
    ' Display time & range measurement on LCD display in inches
        LCDOut $FE,1:FLAGS=0:Pause 250 ' Clear Display
        I2CREAD SDA, SCL, RTCdevice, SecReg,[sec,MINs,hr,day,date,mon,yr]
        LCDOUT $fe,1
        LCDOUT $fe,Line1,Hex2 mon,"/",hex2 date,"/",hex2 yr
        LCDOUT $fe,Line2,hex2 hr,":",hex2 MINs,":",hex2 sec
        Pause 2000                   ' Allow Time for user to view
        LCDOUT $FE,1
        LCDOut $FE,Line1,"Range:"    ' Display on 1st line
        LCDOut $FE,Line2,#w0," in."  ' Display on 2nd line
        PAUSE 5000                   ' Allow Time for user to view
    ' Clear STATUS register & Alarm flags..ready for next interrupt
        I2CWrite SDA, SCL, rtcdevice, StatusReg,[$00]
    LOW ext_pwr  ' Turn off power to the SRF02 at end of display.
                 ' This statement will distort the I2C bus and ext_pwr
                 ' must be set HIGH again before any attempts are made to
                 ' use the I2C bus.
    ' Store range as date-stamped value in EEPROM
        WRITE 17+J,WORD w0          'Store day's range in EEPROM
        PAUSE 10
        Write 16+J,date             ' with day of month date-stamp
        PAUSE 10
    ' Step pointer to next logging address in EEPROM
        J = J + 3
        WRITE 10,J   'Update contents of J index EEPROM memory address
        Pause 10
    PAUSE 470        ' Delay to permit I2C bus to stabilize after SRF02 off
    ' Resume Main Program
@ INT_RETURN
