Questions on ultrasonic distance finder
Results 1 to 20 of 20
Threaded View
  1. #2
    Perth, Australia
    what hardware setup are you going to use?
    i have built one of these before. ive attached a pic if you are interested.
    the main problems i faced was to do with the detection of the reflection. i never managed to get the adc to detect a reflection, so i used amplification circuits and a comparator to detect the reflection and trigger an i/o pin.
    the detection part of my circuit was from this site:
    http://www.best-microcontroller-proj...pic-sonar.html
    I found, however that the transmitter side of that one wasn't great. the best result i got was from using an inductor to build up much larger voltages across the transducer.
    My results were good. I get +/- 1cm at most ranges. By changing the sensitivity of the detector I can shift the effective range. If i set it more sensitive, i get longer range but lose ability to detect short distances. If i set it less sensitive i can get shorter ranges but not long range.
    6cm may be tricky tho. the shortest range ive managed is around 15cm.
    I generate the pulse for 150uS. I found that for my purposes (not needing short range stuff at all - just ranges over 1m), i then wait about 1.5mS before looking for a reflection. Its best to experiment with different times to get the best result for you.
    Hope some of this helps you.
  1. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 09:01
  2. Sharp GP2D12 Range Finder???
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 13th December 2007, 09:21
  3. sensor ultrasonic 8051&PIC
    By hd_uni_pro in forum Schematics
    Last Post: - 13th September 2006, 12:58
  4. ultrasonic sensor
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 9th May 2006, 20:26
  5. SRF04 Range Finder 16F628 R18iXL Board
    By Spindle in forum mel PIC BASIC Pro
    Last Post: - 20th June 2005, 02:08
