Can I have interupts on any pin ?
Results 1 to 22 of 22
    No. You can't have interrupts on any pin. Only pins that have some type of associated interrupt will cause a hardware interrupt.
    Testing inputs pins for high or low logic states is not a hardware interrupt.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    This is an example of what I mentioned earlier.
    I'll call it FAKE INTERRUPT
    It does have a latency of a little over a millisecond, but often it is plenty good enough to do what you need done. You can make the interrupt faster if you wish - but remember each time you enter/leave an interrupt, you are stealing quite a few processor cycles.
    This code will check the status of any pin once per millisecond. It was written for an 18Fxxxx at 40Mhz. This example is checking the status of PORTC.0.
        Changed VAR BYTE
         OldPort VAR BYTE
         T0CON = %10001000 ; turn it on, 16 bits, no prescaler (osc/4)
         CLEAR
    '-----------------  DT_INTS section ----------------------------
            INCLUDE "DT_INTS-18.bas"
            INCLUDE "ReEnterPBP-18.bas"
                  INT_Handler    TMR0_INT,   _FakeInt,   PBP,  yes
        INT_CREATE
    Goto OverInt
    '------------------ Timer 0 interrupt handler-----------------------------------
    FakeInt:
             TMR0H = $D8  ; Preload depends on clk speed
             TMR0L = $F7  ; One millesecond timeout at 40Mhz.
                          ; Always load HIGHBYTE FIRST
             Changed = PortC ^ OldPort
             IF Changed.0 = 1 THEN     ; Pick your pin
                 OldPort = PortC
                 ;;;;  Whatever you want to do when Port bit changes
    @ INT_RETURN
    Overint:
      OldPort = PortC    ; Init the var
    @ INT_ENABLE TMR0_INT
    NormalProgramLoop:
        Goto NormalProgramLoop
    Charles Linquist
    Here's a schematic for 13 pins with interrupts using just two interrupt-on-change pins.
    -Bruce
    tech at rentron.com
    Jan 2006
    Istanbul
    At Post#3, I was trying to explain the same method.
    That's what reminded me I had the schematic...;o)
    -Bruce
    tech at rentron.com
    Dec 2004
    Scarborough UK
    Smile
    WoW guys & gals, im overwhelmed with the response to this, thank you all very much.
    Some of your ideas I have considdered, like a diode to the B0 pin, but I dont think that would work for my app, I need to have as many pins as input as possible which i think is about 33 at most on the 18f4550 (and 2 pins could fire at the same time), I will take a closer look at some of your suggestions on my day off work, it looks like some of it involves assembler which I dont get :-(, but Im sure I will pick something out of your ideas :-), Im just wondering if just polling the pins would be fast enough @ 20mhz, I'm gonna give all your ideas a try this w/end and see what works, thx
    Reading the datasheet & understanding it are two different things.
    Dec 2004
    Scarborough UK
    Smile
    Just an afterthought,
    do all pic micro ports/pins have internal pull up resistors ?, i've been looking at the 18f4550 datasheet but cant tell ?, maybe i'm just stupid or tired lol :-)'
    May 2008
    Italy
    No, internal pullups applys only to portB.
    Al.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 05:07
    Last Post: - 13th December 2008, 17:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
