Can I have interupts on any pin ?
Results 1 to 22 of 22
    Miami, Florida USA
    Bonxy,
    Yes, you can have multiple interrupts. Can you have an interrupt work on any pin on a PIC18F4550? I don't know about that. But can you create a routine where you check the status of the pins that you want and then if a change is made goto to a sub-routine? Something like
    IF PORTX.0 = 1 THEN GOTO SUBROUTINE0
    IF PORTX.1 = 1 THEN GOTO SUBROUTINE1
    Jan 2006
    Istanbul
    Use RB.0 for interrupt pin and connect as many normal pin as you want to this pin via a diode.
    RB0 will interrupt with any of the pins; you will check the status of the pins in interrupt routine.
    Thus, if you connect 10pins with RB0, then you will have 10 interrupt pins.
    ____________________________________
    Wink
    Hi, Bonxy
    You always can use the old method : use an " OR " gate to trigger one interrupt pin of the device.
    after, read ports and just check your inputs as rsocor01 tells, hoping they didn't change state in between ... ( possible issue ... but ...)
    note a couple of MCP 23016 or 23S17 ( Port expanders ) could help a lot here ...
    the question is here : really need it ???
    Sep 2005
    Campbell, CA
    Or - if you can tolerate a little latency -
    You can use a fast timer interrupt (say 1mSec) and check the status of any pin in that interrupt.
    Charles Linquist
    No. You can't have interrupts on any pin. Only pins that have some type of associated interrupt will cause a hardware interrupt.
    Testing inputs pins for high or low logic states is not a hardware interrupt.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2005
    Campbell, CA
    This is an example of what I mentioned earlier.
    I'll call it FAKE INTERRUPT
    It does have a latency of a little over a millisecond, but often it is plenty good enough to do what you need done. You can make the interrupt faster if you wish - but remember each time you enter/leave an interrupt, you are stealing quite a few processor cycles.
    This code will check the status of any pin once per millisecond. It was written for an 18Fxxxx at 40Mhz. This example is checking the status of PORTC.0.
        Changed VAR BYTE
         OldPort VAR BYTE
         T0CON = %10001000 ; turn it on, 16 bits, no prescaler (osc/4)
         CLEAR
    '-----------------  DT_INTS section ----------------------------
            INCLUDE "DT_INTS-18.bas"
            INCLUDE "ReEnterPBP-18.bas"
                  INT_Handler    TMR0_INT,   _FakeInt,   PBP,  yes
        INT_CREATE
    Goto OverInt
    '------------------ Timer 0 interrupt handler-----------------------------------
    FakeInt:
             TMR0H = $D8  ; Preload depends on clk speed
             TMR0L = $F7  ; One millesecond timeout at 40Mhz.
                          ; Always load HIGHBYTE FIRST
             Changed = PortC ^ OldPort
             IF Changed.0 = 1 THEN     ; Pick your pin
                 OldPort = PortC
                 ;;;;  Whatever you want to do when Port bit changes
    @ INT_RETURN
    Overint:
      OldPort = PortC    ; Init the var
    @ INT_ENABLE TMR0_INT
    NormalProgramLoop:
        Goto NormalProgramLoop
    Charles Linquist
    Here's a schematic for 13 pins with interrupts using just two interrupt-on-change pins.
    -Bruce
    tech at rentron.com
    Jan 2006
    Istanbul
    At Post#3, I was trying to explain the same method.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
    Last Post: - 13th December 2008, 18:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
