Anyone using Vacuum Flurecent Displays?
Results 1 to 7 of 7
    Aug 2003
    Default Anyone using Vacuum Flurecent Displays?
    Hi Guys,
    I got two of these yesterday, and it looks like I'm getting a couple more soon.
    My only concern with using them in a project is their tendency to fade with time.
    Having a few backup units helps though.
    This isn't mine, but a project of the guy who did a trade with me.
    it's driven with an Atmel chip.
    Mine are single line, 40 char displays that are driven with the same back-end (HD44780),
    and share the same pinout as parallel LCD displays, making them PicBasic compatible!
    I can't wait to use one.
    Art.
    Art, Are those Nixies or Numetron's behind the Flurecent display? I built a driver for a NIXIE display clock project quite a few years back and it gave me a flash back..... Oh the warm glow of plasma....
    Aug 2003
    They look like either valves or nixies, but it doesn't look like they are being well looked after.
    As I said though, this isn't my stuff, I just got the same displays.
    Mentor, Ohio
    Smile
    Hi Art,
    I used some 4x20 VFD displays several years ago that I got from Rentron.
    Worked great on my project. I think I bought some spares for future
    replacement. I also bought some 4x20 Blue LCD's as a backup. I did
    read about the potential problems that arise over time. I personally see
    see it several times a week on my job as an alarm service tech. We have
    alot of early Radionics panels that used VFD displays that have lost their
    brightness.
    What I did on my project was to use mesages that moved around the display
    so that the same message didn't stay in the same place for more than
    a few seconds. Seems to have done the job. But I do expect to have to
    replace them at some point. That's how you make money in the service
    business. I believe you can adjust the intensity through software so that
    they aren't as bright which might help keep them going longer. You can
    probably put an LDR into your micro and let it adjust the brightness
    depending on the ambient light around your display.
    HTH,
    BobK
    Aug 2003
    Unfortunately I don't know how to change the brightness.
    Pin3, which is usually the contrast adjustment for this pinout,
    is instead used to reset the display. I don't know why you'd want to do that.
    There probably is provision to change it, and I just don't know about it.
    Google certainly didn't help where a datasheet is concerned.
    I like the color of these VFD's and the brightness too.
    But for sure they fade with the usage. I have a HP Printer on my desk that you can hardly see what the display shows in complete darkness!
    And it cannot be replaced with LCD as it is completely different pin-out...
    So now I prefer to use the Blue LCD's an am quite happy about it. My customers too!
    Aug 2003
    Hi again Guys,
    I finally got around to making a test circuit for it.
    There are no datasheets or anything to be found with a Google search,
    so if anyone finds this as a result of their search it might be useful to
    give the screen brightness commands here.
    Pretty simple really, 0x28 is the command for brightness, and that is followed
    by a data byte from 0 - 3, 3 being the lowest brightness setting so:
    LCDOUT $FE,$28,3 ' set VFD to lowest brightness setting
    You'll see I move the display around on the screen as suggested to avoid burning any pixels,
    particularly with a time & date display.. the year 2010 is going to stick around on the
    display for a whole year before changing, so that would ruin it pretty quickly.
    Cheers, Art.
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 18:30
  2. Multplexing two 7-Segment Displays with PIC16F84A
    By lawriem72 in forum mel PIC BASIC
    Last Post: - 19th July 2007, 21:27
  3. large displays
    By George in forum Off Topic
    Last Post: - 18th March 2007, 21:56
  4. LCD Displays
    By Roland in forum mel PIC BASIC Pro
    Last Post: - 16th August 2005, 09:43
  5. Melanie's LCD displays
    By BobK in forum Adverts
    Last Post: - 24th October 2004, 11:27
