Simple ISR?
Results 1 to 7 of 7
Thread: Simple ISR?
    Alabama,USA
    Default Simple ISR?
    My project is a 24hr temp logger. Which logs every 15 minutes for the 24hr period. The 15 minute timer is the PBP “SLEEP” command. After 24 hours the application goes to sleep” @sleep”. I want an interrupt on GP2 external interrupt pin to stop the 15min. timer or the “@sleep” and send the program to a PBP routine to RS232 dump to PC. At that time the job is done, unit goes to low power state until power disconnect. I don’t want to use ON INTERRUPT, can’t wait 15min. to print. Once interrupted I don’t need to save any variables, or STATUS or PCLATH (<2k) logging is done, I only need a “goto _printout” placed at location 04. So how do I accomplish that? AND have I missed something of the process?
    @ DEVICE PIC12F683,MCLR_OFF,INTRC_OSC_NOCLKOUT ,WDT_ON,BOD_OFF
    @ DEVICE PWRT_ON,FCMEN_OFF,IESO_OFF,PROTECT_ON
    OSCCON=%1110000
    Define OSC 8
         VRCON  = 0
         ADCON0 = 0
         OPTION_REG = %01000000  	;rising edge
         ANSEL  = 0    			;digital all
         CMCON0 = 7
         INTCON = %10010000         	;Globle set, GP2 ext int, flg clr
         GPIO=0
         TRISIO=%00001100		;GPIO.2 input
    	;GPIO.2 held low until button push +5v
         Blink   var GPIO.4
         GOTO Start
         define INTHAND myint
         asm
              myint goto _printlog
                endasm
    Start:
                  -----     LOG DATA for 24hrs
    Printlog:
    	 -----     RS232 to PC
    	INTCON = %10010000   ;in the case another print out is needed
    	@sleep
    I’ve written a small INT test program to work this out but I’m not having any luck. On compile I get the error “undefined symbol myint” & “opcode expected instead of myint”
    I remove the myint from the asm line and the opcode error goes away. However I think this is needed as it is the ASM label. This ASM method is right out of the 2.60 manual. What is it I’m not getting? Comments Please!
    Bombay, India
    I tried out your code. The only change that needs to be done is in how you define myint
    myint should start in the 1st column of your file.
    Alabama,USA
    Default Reply
    Thank you Jerson for your reply. I did not understand the relevance of the first column positions of the instruction. As a matter of fact the manual has the instruction on the first column. This should get me up and running. Thank you again for your response
    Alabama,USA
    Default Reply
    I have written this short piece of code to test the interrupt. IT Works! but only ONCE... For some reason it will not interrupt the second time unless I reset the processor with the power. I can't see a problem. I am resetting INTCON before return to main program. ???
    @ DEVICE PWRT_ON,FCMEN_OFF,IESO_OFF,PROTECT_OFF
    OSCCON=%1110000
    Define OSC 8
         VRCON   =  0
         ADCON0 =  0
         CMCON0=  7
         INTCON = %10010000         	;GlE set, INTE set, INTF clr
         GPIO=0
         TRISIO  = %00001100		;GPIO.2 input
          Avar    var byte
          Blink   var GPIO.4
          TX      var GPIO.5
          GOTO Main
    asm
    endasm
    Blinkled:
        for Avar=1 to 4
        HIGH    blink
        pause   100
        low     blink
        pause 200
        next Avar
        Serout2 tx, 84, ["   This is a test, This is only a test",13,10,13,10]  ;print to PC
        goto Blinkled
    printlog:
        Serout2 tx, 84, ["   An Interrupt has occured on GP2",13,10,13,10]
        INTCON=%10010000  ;set GIE, INTE and clear INTF
        goto Main
    Bombay, India
    your printlog is an ISR (interrupt service routine) and should end with a return not a goto main. Try that
    Alabama,USA
    Default Reply to Jerson
    Jerson,
    Yes, I had forgotten about the address that was pushed on the stack by the interrupt. I tried a RETURN and @RETFIE , the micro locked up for a couple of seconds then restarted, I think by WDT, and would not re-interrupt. I know I have to deal with the stack but RETURN will load an address I don’t want to use. So my challenge it to find a way to POP the stack, discard the address and load a new address while still resetting interrupt bits. It looks like there is NO easy way to do this. I’m sure that is why DT_INT is so popular. By the way thanks again for lending a helping hand to the struggling hobbyist, mainly me. I’ll keep working on this problem and post any success.
    WANTED: easy way to use Ext Interrupt to change the course of a program.
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 11:45
  2. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 07:19
  3. Replies: 0
    Last Post: - 3rd February 2009, 00:23
  4. Jump from ISR
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 15th May 2008, 21:54
  5. Replies: 4
    Last Post: - 7th September 2005, 15:11
