I can not figure out an LCD issue
Results 1 to 15 of 15
    Yup
    A bad connection will make all kinds of strange things happen.
    malc-c's Avatar
    malc-c Guest
    Mike,
    Not sure if I'm correct, but I seem to remember reading that solder less breadboards can cause issues as they can have a high capacitance. Maybe this was part of the problem causing the timing issue.
    Glad to hear you have this part resolved and best of luck with the rest of your project
    Wink
    Alain,
    What did you mean by this?
    Quote:
    may be the missing LCD Settling time @beginning of the program ???
    Hi, I just mean place a pause 500 to 700 ms before sending the very first command to the LCD.
    just to let it be ready for receiving infos ...
    Moreover
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    are the correct value for LCDs
    in case of using OLEDS ... add 50% to both !!!
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD issue with EasyPIC5
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th June 2008, 10:17
  5. LCD will not start
