I can not figure out an LCD issue
Results 1 to 15 of 15
    May 2009
    Montreal, QC, Canada
    Dave,
    I have tried
    DEFINE LCD_COMMANDUS 1000 and 4000
    DEFINE LCD_DATAUS 25 and 100
    with no aparent changes.
    Malcom,
    The display does work at 8 MHz with a 4 MHz resonator but the chip's timing is doubled and that is what I am trying to figure out. so a PAUSE 1000 will last 2 seconds instead of 1 second. The timing for this project is important because I want to build an ultrasound distance mesurement and so I have to time the echo received after sending an output burst of 40 KHz. I think I am far from my goal but I can't get started with the fun part untill I have figured out my issue with the timing problem.
    Alain,
    What did you mean by this?
    may be the missing LCD Settling time @beginning of the program ???
    For the record this is my hardware configuration and with an oscilloscope I see the 5V as pure DC 5.12V
    May 2009
    Ok so here is a positive update...
    I had removed my resonator last night to rule it out and got the same issue with the chip's internal oscilator. Today I just put back the resonator and set _XT_OSC again and now it is working fine at 4 MHz.
    Furthermore...! if I remove the LCD_Anypin, it is now still working with the standard version.
    So please correct me if I am wrong but I am working with a breadboard and I suspect when I had the resonator at first, there was a bad contact with one of its pin!
    Thanks to all for your responses, it kept me going.
    Mike
    Yup
    A bad connection will make all kinds of strange things happen.
    malc-c's Avatar
    malc-c Guest
    Mike,
    Not sure if I'm correct, but I seem to remember reading that solder less breadboards can cause issues as they can have a high capacitance. Maybe this was part of the problem causing the timing issue.
    Glad to hear you have this part resolved and best of luck with the rest of your project
    Wink
    Alain,
    Hi, I just mean place a pause 500 to 700 ms before sending the very first command to the LCD.
    just to let it be ready for receiving infos ...
    Moreover
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    are the correct value for LCDs
    in case of using OLEDS ... add 50% to both !!!
  1. 16f688 LCD what have I done wrong
    Last Post: - 8th August 2009, 20:54
  2. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  3. LCD issue with EasyPIC5
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 15th June 2008, 10:17
  5. LCD will not start
