The following works for me using an EasyPIC5 board with the LCD on PORTB, 18F4550 with 20Mhz xtal (mainly as that's what I'm using for a current project and couldn't be bothered to change the PIC !)
Using DEFINE OSC 20 I had erroneous results on the LCD, so it's obviously a timing issue with your 4MHz resonator.Code:ASM ; 18F2550/4550, 20mhz crystal __CONFIG _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L __CONFIG _CONFIG1H, _FOSC_HSPLL_HS_1H __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H __CONFIG _CONFIG3H, _PBADEN_OFF_3H __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L ENDASM DEFINE OSC 48 TRISB = 0 ' Make PORTB all outputs CMCON = 7 ' Disable comparator ;----[LCD definitions]------------------------------------------------------ DEFINE LCD_DREG PORTB ' LCD Data port DEFINE LCD_DBIT 0 ' starting Data bit (0 or 4) DEFINE LCD_EREG PORTB ' LCD Enable port DEFINE LCD_EBIT 5 ' Enable bit (on EasyPIC 5 LCD) DEFINE LCD_RSREG PORTB ' LCD Register Select port DEFINE LCD_RSBIT 4 ' Register Select bit (on EasyPIC 5 LCD) DEFINE LCD_BITS 4 ' LCD bus size (4 or 8 bits) DEFINE LCD_LINES 2 ' number of lines on LCD DEFINE LCD_COMMANDUS 2000 ' Command delay time in us DEFINE LCD_DATAUS 50 ' Data delay time in us LCDOUT $FE,1 ' clear screen LCDOUT $FE,$80,"LCD Prototype MJ" ' Use $Fe,$C0 to address the second line LCDOUT $FE,$C0,"Timer testing" pause 5000 LCDOUT $FE,$C0," " Start: ' Program starts here goto start end
