A Simple IOC Routine (Interrupt On Change)
Results 1 to 7 of 7
    Hi, Luis
    I 've already made much worse than that ...
    Darrel can confirm !!!
    But your code goes straight to the pBp libraries @ location 4 , if you enable GIE ... ( I verified it with MPSIM !!! )
    Program pointer passes over ALL the PAUSE library ... luckily it's the only routine here...
    DANGER !!!
    May 2007
    Sitting in a loop while waiting for something to happen (in this case, polling the RAIF flag) isn't really what interrupts are about.
    To be really useful, it should actually interrupt whatever your program is currently doing when RA0 changes state. For example, let's say you have a routine the is blinking PORTC.5 at a slow rate of 500mS ON and 500mS OFF continuously in a loop. If the state of RA0 changes (eg. by using a switch or sensor), then you want the blink rate to go faster rate, say 100ms ON and 100ms OFF.
    Feb 2010
    Acetronics, i dunno understand, i'm newbie and my english is not excellent, but since i'm going to use IOC for a button and external INT over RA2 for measure a pulse, when i get there, i think i'll see the problem.
    Meanwhile if i'm going to use INT over RA2 to measure pulse width, i do need to send first a dummy pulse before the pulse to measure?
  1. Can't ID interrupt source with this IntHandler??
    Last Post: - 14th November 2008, 18:25
  3. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
  4. Simple Interrupt Program
    By eoasap in forum General
    Last Post: - 28th October 2005, 17:22
