Using SPI
Results 1 to 7 of 7
Thread: Using SPI
    By "bitbang" do you mean the software method where certain pins are turned on/off at the correct time?
    Yes.
    Using that method would i be able to communicate with an SD card really slow? Im thinking less than 1Hz while testing so i can see the data in realtime. I would like to use this idea for testing the hardware version too. The datasheet says the SPI clock can be controlled by timer2 which i could slow down. Would an SD card be alright with such a slow transfer or is there any kind of timeout on them?
    Slower but not sure how much.
    Ive read the bit about SSPSTAT and SSPCON1. The configuration i had is the same as what you showed. I understand what the options mean but do you know which ones i need to work correctly with and SD card?
    SSPSTAT = %11000000 or SSPSTAT = %01000000 Both work OK.
    I understand #5 but one thing i cant seem to find out (even from the datasheet) is how the clock works. I assume that writing to SSPBUF will cause 8 cycles on the SPI clock pin then it stops instead of cycling constantly.
    Yes. Repeat for Lowbyte and Highbyte.
    Norm
    Jun 2007
    Mansfield, UK
    Hi, Ive done a lot of reading and it seems that the clock and be slowed down as much as you want which is good for testing. Im getting a little confused by the actual SD protocol though. Different sites are saying different things.
    I have some example code in C. I dont completely understand C but it looks like its saying things should happen in this order:-
    Enable the SPI interface
    Send 80 clocks using dummy bytes (0xFF)
    Enable CS (low)
    Send another dummy byte
    Send the init command (0x40, 0x00, 0x00, 0x00, 0x00, 0x95)
    Repeatedly send a dummy byte until the card replies
    Another site says the CS pin should be asserted before sending the 80 clocks. This is confusing as the pin is active low. It did read as though "assert" means low but as this C example seems to be the oposite i assume it means high.
    For SD card go here and look at SDFS3.zip
    http://www.melabs.com/resources/samples.htm
    It is so much easier than bit-banging. Added plus is the FAT16 file system.
    Jun 2007
    Mansfield, UK
    Hi, Since my last post Ive been doing some testing and i actually got a PIC to read data
    Ive been using the hardware SPI instead of bit-banging. Thanks for that link though because the next thing i need to do is figure out FAT16. Im working in ASM but having the example in PBP makes it easier to read :P Thanks!
  1. Using SPI with External Interrupts
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 05:08
  2. 16-bit SPI problem
    Last Post: - 19th June 2008, 16:42
  3. SPI Interfacing
    By toofastdave in forum Serial
    Last Post: - 18th November 2007, 12:15
  4. SPI configuration PIC versus Atmel
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 10th July 2007, 20:17
  5. How to configure SPI in PICBASIC PRO?
