Rough 'n Ready Audio Frequency extraction with a PIC
Results 1 to 34 of 34
    Mar 2009
    Time to revisit this old thread of mine, as I now have a cool use for frequency detection in my ongoing guitar project 'X'.
    Basically, I want a PIC on my cct to establish when the same guitar note has been played for 'x' seconds (user configurable) - once this condition has been met, then the PIC will inoke some cool 'stuff' to kick in!
    I parked this 'early exploratory thread' having gotten the comparator/frequency detect to work simply on a basic 12f683 - back then interrupts were fairly new to me...whilst now I don't pretend that I'm interrupt savvy (I don't need to be thanks to Darrel's routines!)...I think it's time to revisit & try to apply to the more advanced PIC I'm using now - a 16F690.
    Now looking at the comparator module on the 16f690 datasheet - wooooaaah.....a bit scary. So a couple of early questions before I have a pop at this tonight.
    Due to the layout of my board, pin 7 looks like a prime candidate for getting my analogue signal into the PIC - could someone please confirm that this is indeed a valid comparator input pin?!!
    Ok, wrt what signal I'm feeding into the comparator - essentially with no guitar signal present the quiescent voltage will be +4V (which is also the PIC rail voltage) - in my cct config, a diode half wave rectifies the guitar signal so when a signal is present ....the PIC will just see negative portions of the signal.
    So, with respect to the voltage to 'flip' the comparator - I guess, I'd need something in the region of +3V? (ie any incoming signal with a negative swing of 1V will flip the comparator). a quick look at the datasheet suggests there are 16 'reference levels' that can be used internally within the PIC - cool, looks like that should be ok (I'll need to have a dabble with the VRCON register)
    Ok, now assuming I get the comparator 'flipping' at the right voltage level .....what to do with it to get the most dependable frequency detection going on.
    Just to reiterate - I would like to to detect when the guitar frequency has NOT changed for 'x' seconds (the' x' being user selectable selectable by a pot - I have this particular bit covered off already)
    I see that DT's interrupts have a comparator interrupt....presumably that can be brought into play here?
    So what would be a good building block here?
    1. Start a countdown timer configured for 'x' seconds. (as mentioned above)
    2. start looping (say a 300ms loop...whatever time window is needed to detect individual fret frequencies for the frequency range of guitar ...approx 70Hz thru 1300khz))
    3. Clear comparator 'count' (a program variable)
    4. Enable comparator interrupts
    5. Start counting comparator interrupts
    6. Stop loop, compare present number of comparator interrupt count with previous ...
    i) if comparator count is 'within limits' then keep repeating (same note has been held held)
    ii) if 'outside limits...then reset step 1 countdown timer (ie a different note detected, so reset & start again)
    7. countdown timer expires - condition therefore met (ie same note held for x seconds)....go and invoke some cool stuff!!
    Any thoughts, problems etc? (I should point out that the guitar has a sustain device onboard, so the note can/will ring on forever - also such a sustained note is pretty sinuisoidal, stable....so the comparator should flip reasonably dependably)
    Mar 2009
    Well, I got a simple form of frequency detection going on with my 16f690 last night.
    I fed a sine wave into one of the 16f690s comparator input pins & used DT's comparator interrupt routine - the associated handler incremented a count with every comparator flip (interrupt),
    I then simply used timer1 set to overflow at 0.5s - at overflow the comparator count is multiplied by two (to get the equivalent count for 1 second - so the end result was in Hertz).
    I was getting reasonable accurate frequency detection - the 'count' number danced about +/- 2 or 3 (therefore ultimately 2 or 3Hz) ...which I'm pretty sure could probably be averaged out to bring this error down a little).
    I wasn't able to get the 16f690' internal VREF to work (I was using the external VREF pin set at 1/2 VCC)
    This VREF issue aside (which I'll revist soon), what I now need is a 'rolling window' in code, which goes something like thus...
    "If the comparator count hasn't changed - give or take - for the past 1.5 seconds (ie rolling window), then that must mean a note is presently being held, if so ...go & do stuff!"
    Now there are only two timers on the 16f690....and I was really hoping to keep one of them in reserve for flashing LEDS (the LED 'flash rate' depending on the mode), so I'm looking for creative ideas that would allow me to apply the above 'condition' without wasting anther timer!
    Grateful for any input here!
    Mar 2009
    Ok, I think I have the loose makings of the necessary code for a rolling 1 second window to check whether the frequency has remained the same...
    (the signal to be monitored is fed into comparator1)
    INCLUDE "DT_INTS-14.bas"
    INCLUDE "ReEnterPBP.bas"
    INCLUDE "Elapsed_INT.bas"  ; Elapsed Timer Routines
            INT_Handler   TMR1_INT,  _timer1_interrupt,   PBP,  yes
            INT_Handler   CMP1_INT,  _comparator_interrupt,   PBP,  yes
    @   INT_ENABLE  TMR1_INT  ; Enable Timer 1 Interrupts
    @   INT_ENABLE  CMP1_INT  ; Enable comparator1 Interrupts
    nochange_count var word   'count number of 'timer overflows' where frequency hasn't changed
    comparator_count var word   'a variable to count number of comparator interrupts (frequency detection)
    loop:
    if nochange_count > 3 then     'ie frequency has remained the same for 1 second
    nochange_count = 0
    gosub dostuff
    goto loop
    '---[Timer1 - interrupt handler]--------------------------------------------------
    timer1_interrupt:        'prescaler set for circa 250ms
    if comparator_count = previous_comparator_count then   'needs a 5% 'deviation' allowable error to go here!!
    nochange_count = nochange_count+1   'count how many times frequency has NOT changed
    nochange_count = 0 ' if frequency has changed, then zero counter and start over
    previous_comparator_count =  comparator_count
    comparator_count = 0
    @ INT_RETURN
    '---[Comparator1 - interrupt handler]--------------------------------------------------
    comparator_interrupt:
    comparator_count = comparator_count +1
    @ INT_RETURN
    There may be some syntax errors in there (I'm at work!), but that's the basic framework - what I don't know how to do is the 'deviation' part (bolded in red above).
    How can I have an 'if' condition that checks to establish if present count is 'within 5%' of previous count' (plus or minus), therefore....
    if comparator_count = previous_comparator_count '+ or -' 5%
    Two 'AND'ed ifs?
    Many thanks!
    Mar 2009
    At the risk of talking to myself (first sign of madness)....
    I now have the 'framework' of code needed to detect when a frequency is stable- happy.
    What I've got issues with is my raw (frequency) input data being a bit 'jittery'. By this I mean if I dial in 100Hz on my sig gen, for every 0.5sec I get readings like this
    50 49 50 50 51 50 51 50 49 50 50 50 51 51 50 50 (it should be a steady reading of 50)
    ....& so on.
    Now for a reasding of 50, a plus or minus variance of 1 either side equates to jitter 'error' of 4% ....and this is for digital?!!!
    So my approach must be bad! (ok, so the title of the thread is rough 'n ready frequency extrcaction - but a 4% jitter erroris just too rough!)
    Now for the life of me I can't figure out why a stable clean sine wave into this chain should cause jitter ...
    Sig gen Sine Wave (ie clean & steady as a rock) ->PIC comparator->PIC comparator generates an interrupt->comparator generated interrupts are counted->tmr1 overflows & comparator interrupt 'total count' is stored
    Now I can average it out (but this will incur delay in detecting steady frequency - which is my goal) , but I'd rather get to the root of the jitter in the first place!
    I am listening.
    I am learning.
    VERY INTERESTING STUFF!!!
    As a moderator I will ask you to consider writing an article out of all of this when you feel the project is ready.
    Please keep it coming!!!
    HankMcSpank ,I would personally count the time between interrupts instead of the number of interrupts in 1/2 second. That way you can increase the low end resolution you are looking for. Even a 1000 hz clock will give you .1% resolution at 100 hz....
    Mar 2009
    Dave you're right on the money there - I'm now getting much better stability with your suggested method, here's what I'm seeing onscreen for Timer1 counts between comparator interrupts (this was for approx 100Hz)...
    Timer1 Count= 5007
    Timer1 Count= 5005
    Timer1 Count= 5007
    Timer1 Count= 5004
    Timer1 Count= 5007
    Timer1 Count= 5004
    Timer1 Count= 5007
    Timer1 Count= 5005
    Timer1 Count= 5007
    Timer1 Count= 5004
    Timer1 Count= 5007
    Timer1 Count= 5005
    Timer1 Count= 5007
    Timer1 Count= 5004
    Timer1 Count= 5007
    Timer1 Count= 5004
    Timer1 Count= 5007
    Timer1 Count= 5004
    ...so my jitter is now something like 0.001% - that couls be down to my sigen not being stable even - it has been known to drift about a bit)
    I've got a bit of a mental block with the last remaining bit though (converting to frequency in hertz! - which for all I don't actually need the result in Hz - as I'll just be comparing on the timer count alone to establish whether of not the frequency is stable - it'd be a nice to have!!)
    So, what I'm seeing with my timer counts...
    A 'Timer1 count' of 5000 equals 100Hz
    A 'Timer1 count' of 500 = 1000Hz
    Therefore the timer clock cycle = 2us (0.000002s)
    What formula do I use to convert my Timer1 count into Hertz? (it's the floating point aspect that messing me up - else I'd just use this simple formula....
    1 / ('timer1 count' * 0.000002)
    If I add to the left side of the equation (to take the right hand side out of 'decimals' territory)...it cranks up into the millions - tilt!!!!
    So how should I approach this Hertz conversion?
  1. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 02:47
  2. PIC Audio
    By toofastdave in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 14:49
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
  4. Audio Encoding and playback in a PIC
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 09:56
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 07:20
