Rough 'n Ready Audio Frequency extraction with a PIC
Results 1 to 34 of 34
    Mar 2009
    Guys...thanks for your input - I'll take time later to consider them all in detail.
    In the meantime, a bit more info.
    I need to capture the frequency soon after the string is plucked but not too soon else too many complex harmonics are still embedded in the signal. I'd imagine coming in to make my 'sample' about 300ms after the pluck (I have a preset PIC threshold that when breached assumes a note has been plucked, which will allow me to pause 300ms before sampling).
    I can't imagine going past 500ms after the note has been plucked (else the note will have decayed too much) so this only gives a maximum window of about 200ms to glean what the frequency is.
    If it helps, I'm using a 16F690.
    Acetronics - just seen your post - I'm using a sustainer which thankfully drops out all harmonics and leaves a relatively pure fundamental ( http://www.youtube.com/user/hankmcsp.../0/u6gm5fY1wM0 ie a nice sinewave!) Wrt to sustain - some frquencies are quite tricky to sustain, so I need to know when they're plucked to trigger special handling
    Mar 2009
    Got to laugh - 16f690 ...absolute mare for a noobesque personage like meself..
    I wouldn't mind but I've tackled so much with that PIC variant...but comparators? WTF?! The datasheet has ma heed buzzin.
    I've decided a nice easy entry into the world of comparators is now going to be with a simpler 12F683. Once I nail the concepts with that, then I shall take a few swigs of stiff whisky & get out the 16F690 datasheet again - were microchip having a laugh with that on?
    I've thought about doing something like that too,
    And I think without external hardware and using the comparator, the DFT idea Josuetas was working with a while back might have the best chance at detecting the notes.
    It may even be able to detect multiple notes at the same time (chords).
    I played with the spreadsheet, but didn't try any hardware.
    And whether the resolution will be tight enough to distinguish 9/8, 10/9 and 16/15ths steps, I don't know either.
    It was originally for DTMF tones.
    Might be worth a look though.
    http://www.picbasic.co.uk/forum/show...2606#post42606
    And the original AppNote (AN257) ...
    http://www.microchip.com/stellent/id...pnote=en024294
    Mar 2009
    Thanks Darrel....I'll check it out later.
    So here's the ludicrously simple 'get me up & running' setup I have (lifted/edited fromthe Microchip Tips' n trick sheet)
    I put a sawtooth from a sig gen on the comparator input, but get nowt on the output
    Now like I say, I always struggle with the registers - and even then, it's been a while - so try not to laugh...
    @MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON
    @MyConfig = MyConfig & _MCLRE_OFF
    DEFINE OSC 4           ' Internal 4MHz
    CMCON0 = %00000001   	'CIN pins are configured as analog, COUT pin configured as Comparator output?
    ADCON0 = %00000000	'ADC disabled?
    ANSEL = %00001111	'All Analogue inputs enabled?
    TRISIO = %111011	'GPIO2 output (Comparator Out)
    ' PIN# NAME     USE & CONNECTION
    '  1   Vdd      +5VDC power supply
    '  2   GPIO.5   Debug Port (PicKit2 needs switching from here to pin Pin 7 to allow programming)
    '  3   GPIO.4
    '  4   GPIO.3
    '  5   GPIO.2   Comparator Out (GP2)
    '  6   GPIO.1   CIN-  Signal In  (GP1)
    '  7   GPIO.0   CIN+  trigger level (GP0)
    '  8   Vss      Power supply ground
    EDIT Ok, spotted it..
    ANSEL = %00001011		'All Analogue inputs except AN2 enabled
    & here we have an output...
    Now...what to do with the output?!!!
    California, USA
    Quote Originally Posted by HankMcSpank View Post
    On the rising edge of your square wave, start a timer running. When the next rising edge comes along, grab the timer count so you can calculate the period of the square wave, and reset the timer for the next go around.
    If your waveform is symmetrical you could start the timer on the rising edge and stop on the falling edge and get your frequency in 1/2 cycle.
    Maybe...
    steve
    Mar 2009
    Well I went for the most simplistic approach first....
    temp var byte
    temp = 0
    start:
        count  GPIO.4, 100, temp
        DEBUG  "Count = ", DEC temp, 13, 10
        temp = 0
        GOTO start
    & it works - the count for 100ms is pretty much bang on ...does jitter about by 1 or so at the lower frequencies
    I realise for a 'sig gen' sourcedsine wave this isn't much of a breakthrough (other than it is for me getting all this comparator stuff melarkey working) - I'm sure guitar signal might be a bit more tricky (one for tomorrow night now).
    Here's 659Hz (Top E String fretted at the 12th), the PIC 100mS pule in count for that frequency matches what I'd anticipated on my spreadsheet...
    Mar 2009
    Time to revisit this old thread of mine, as I now have a cool use for frequency detection in my ongoing guitar project 'X'.
    Basically, I want a PIC on my cct to establish when the same guitar note has been played for 'x' seconds (user configurable) - once this condition has been met, then the PIC will inoke some cool 'stuff' to kick in!
    I parked this 'early exploratory thread' having gotten the comparator/frequency detect to work simply on a basic 12f683 - back then interrupts were fairly new to me...whilst now I don't pretend that I'm interrupt savvy (I don't need to be thanks to Darrel's routines!)...I think it's time to revisit & try to apply to the more advanced PIC I'm using now - a 16F690.
    Now looking at the comparator module on the 16f690 datasheet - wooooaaah.....a bit scary. So a couple of early questions before I have a pop at this tonight.
    Due to the layout of my board, pin 7 looks like a prime candidate for getting my analogue signal into the PIC - could someone please confirm that this is indeed a valid comparator input pin?!!
    Ok, wrt what signal I'm feeding into the comparator - essentially with no guitar signal present the quiescent voltage will be +4V (which is also the PIC rail voltage) - in my cct config, a diode half wave rectifies the guitar signal so when a signal is present ....the PIC will just see negative portions of the signal.
    So, with respect to the voltage to 'flip' the comparator - I guess, I'd need something in the region of +3V? (ie any incoming signal with a negative swing of 1V will flip the comparator). a quick look at the datasheet suggests there are 16 'reference levels' that can be used internally within the PIC - cool, looks like that should be ok (I'll need to have a dabble with the VRCON register)
    Ok, now assuming I get the comparator 'flipping' at the right voltage level .....what to do with it to get the most dependable frequency detection going on.
    Just to reiterate - I would like to to detect when the guitar frequency has NOT changed for 'x' seconds (the' x' being user selectable selectable by a pot - I have this particular bit covered off already)
    I see that DT's interrupts have a comparator interrupt....presumably that can be brought into play here?
    So what would be a good building block here?
    1. Start a countdown timer configured for 'x' seconds. (as mentioned above)
    2. start looping (say a 300ms loop...whatever time window is needed to detect individual fret frequencies for the frequency range of guitar ...approx 70Hz thru 1300khz))
    3. Clear comparator 'count' (a program variable)
    4. Enable comparator interrupts
    5. Start counting comparator interrupts
    6. Stop loop, compare present number of comparator interrupt count with previous ...
    i) if comparator count is 'within limits' then keep repeating (same note has been held held)
    ii) if 'outside limits...then reset step 1 countdown timer (ie a different note detected, so reset & start again)
    7. countdown timer expires - condition therefore met (ie same note held for x seconds)....go and invoke some cool stuff!!
    Any thoughts, problems etc? (I should point out that the guitar has a sustain device onboard, so the note can/will ring on forever - also such a sustained note is pretty sinuisoidal, stable....so the comparator should flip reasonably dependably)
  1. Measuring change of frequency with PIC
    By Aussie in forum mel PIC BASIC Pro
    Last Post: - 19th July 2007, 01:47
  2. PIC Audio
    By toofastdave in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 13:49
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  4. Audio Encoding and playback in a PIC
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 08:56
  5. Frequency Counter using PIC and PicBasic
    By PICtron in forum mel PIC BASIC Pro
    Last Post: - 28th January 2005, 06:20
