Compile error & syntax error on the word "loop:" as a label?
Results 1 to 5 of 5
    Mar 2009
    Colorado
    Default Compile error & syntax error on the word "loop:" as a label?
    I am getting a wierd compile error on my PICBASICPRO program in which I am using a loop on a label named "loop:". It also indicates a sytax error on the GOTO statement at the end of the loop. I don't understand why since the word loop is not a reserved word or a PICBASIC coding statement. Can anyone tell me why this would be happening. Here is the code excerpt where this is happening.
    loop:
        I2CREAD PORTC.4,PORTC.3,$E0,0,[srfver]          ' Read version number from srf02
        SEROUT PORTC.1,2,[1,"Software v: ",#srfver,13]  ' Put it on the screen
        I2CWRITE PORTC.4,PORTC.3,$E0,0,[81]             ' Request start of ranging
        pause 100                                       ' Wait for ranging to finish
        I2CREAD PORTC.4,PORTC.3,$E0,2,[b1,b0]           ' Get the ranging results
        SEROUT PORTC.1,2,["Range: ",#w0,"   "]          ' Display range data to the screen
        PAUSE 100
    GOTO loop
    Aug 2008
    I have no problem here using "goto loop"
    California, USA
    I believe that "Loop" is a reserved word in newer versions of PBP.
    Use a different label....
    steve
    Mar 2009
    Colorado
    Default You are right, Butcher!
    Quote Originally Posted by Byte_Butcher View Post
    steve
    You are right! I had checked all PBP statements in version 2.6 but didn't check Appendix C that lists reserved words....and there it was!
    Thanks for catching this!
    To find LOOP ...
    Look at DO.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 04:56
  5. calculation problem
    Last Post: - 31st March 2006, 16:23
