Please help with 1-wire DS1820
Results 1 to 6 of 6
Threaded View
  1. #3
    Wink
    Quote Originally Posted by Pic2008 View Post
    Did you try to include the following:
    DEFINE OSC 20 ' 20Mhz Osc
    if using 8 Mhz Xtal, your DEFINE must be OSC 8
    also ...
    OWOut DQ, 1, [$CC, $44] ' Start temperature conversion
    Pause 750
    will be nice.
    no need for
    OWIn DQ, 4, [count_remain] ' Check for still busy converting
    that, alone, doesn't check for anything ...
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
