12F675 and LM35 coding issue
Results 1 to 19 of 19
    Wink
    Hi, Bobbo
    For the Glow-igniter, I've published an advanced one ... several years ago.
    Article is written in French ( ... ! ) so, the question ...
    Do you read French ??? ( even under torture ...)
    Mar 2010
    Alain,
    My French is nowhere near as good as your English, :-)
    Thankfully, the internet has given us google translate which works quite well with french and where it stumbles I can normally work out the meaning when put into the correct context.
    I've had a look around but am a bit confused around 2 things.
    1. I'll need a jumper to allow the user to input "Programming mode" - Not sure where to put it, would GP3 with a pulldown res work or can I use any other GP?
    2. Once I have read the value I can flash the LED a couple of times to show the user the chip has the reading, however, when the chip reboots, how do i store the value in memory that will not be reset on a power cycle, :-)
    Easy to explain but quite complex principles to work out, :-) seems like i might be getting ahead of myself.
    Hi, Bobbo
    have a look to this program ...
    It's not the glow driver ( you would be lost @ first lines ...) but a lighting system shown on RC Groups.
    as processor is a 12F675 ... it will be easier.
    But main pulse handling routines are in ...
    Mar 2010
    Ok, wow, that code has some awesome information in it, going to be fun getting this to work.
    You've also set a standard as to what my code should look like, :-) I was never very good at commenting when I did programming, am learning that its almost mandatory in the real world, :-).
    Thanks a mil
    Rob
  1. 12F675 cant serout to PC
    By ruijc in forum General
    Last Post: - 3rd December 2007, 00:11
