problem using GOSUB under interrupt
Results 1 to 11 of 11
    Apr 2009
    Quote Originally Posted by Charles Linquis View Post
    And while you are at it - take a look at Darrel Taylor's Instant Interrupts. They are almost as easy to use as ONINT-GOTO, and they have a lot of advantages -they can't be blocked, the code generated is smaller, the int latency is less...
    Yeah, I saw a bit... I will investigate more if they could be easily applied to my program.
    Apr 2009
    tried Taylor's int managment. It doesn't work... gives those error on PicBasic Pro / MicroCodeStudio+:
    Are you using MPASM as the assembler? You have to if you're going to use DT-INTS.
    Apr 2009
    yes I use Mpasm
    OK, did you also include ReEnterPBP-14.bas or ReEnterPBP-18.bas depending on what type of chip you're using? Which chip are you using by the way?
    Apr 2009
    I'm using 18f2525 and yes, I also put the INCLUDE "ReEnterPBP-18.bas"...
    Which version of MPASMWIN is better?
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 11:45
  2. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 06:11
  3. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 7th June 2006, 23:36
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. ds1307 from f877 to f452 not work
    By microkam in forum mel PIC BASIC Pro
    Last Post: - 7th July 2005, 00:02
