Doubt with interrupt on change
Results 1 to 3 of 3
Threaded View
  1. #2
    Hi lugo.p,
    Let's start off with, change the big old Capital B to the word code, then your code tag will work, do it on both ends.
    Add this to your code along with the proper configs and define your OSC.
    ON INTERRUPT GoTo disparo
    INTCON = %10001001
    'Bit 0 = RAIF      Port A Interrupt Flag
    'Bit 1 = INTF      INT Flag
    'Bit 2 = T0IF      Timer zero Interrupt Flag
    'Bit 3 = RAIE      Port A Interrupt ENABLE
    'Bit 4 = INTE      INT Enable
    'Bit 5 = T0IE      Timer zero Interrupt Enable
    'Bit 6 = PEIE      Peripheral Interrupt Enable
    'Bit 7 = GIE       Global Interrupt Enable
    IOCA = %00000001   ' enable IOC on RA0
    'Bit 0 = RA0 interrupt on change
    'Bit 1 = RA1   "   "    "   " "
    'Bit 2 = RA2   "   "    "   " "
    'Bit 3 = RA3   "   "    "   " "
    'Bit 4 = RA4   "   "    "   " "
    'Bit 5 = RA5   "   "    "   " "
    'Bit 6 = Unimplemented
    'Bit 7 = Unimplemented
    OPTION_REG = %00000000
    'Bit 0 = PS     Prescaler
    'Bit 1 = PS     Prescaler
    'Bit 2 = PS     Prescaler
    'Bit 3 = PSA    Prescaler Assignment bit
    'Bit 4 = T0SE   Timer zero source edge select bit
    'Bit 5 = T0CS   Timer zero clock source select bit
    'Bit 6 = INTEDG Interrupt Edge Select bit
    'Bit 7 = RAPU   PortA weak pullup bit
  1. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. Can't ID interrupt source with this IntHandler??
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
