Simultaneous programming of multiple pics - is it possible?
Results 1 to 8 of 8
    Not something I'd recommend, for sure, but just thought I'd share. Back in the early 80s, our CPM PCBs had EPROMs which would take forever to program; verifying them was much faster. So, we'd just stack up about 5 units one on top of the other, and program them. Then, verify them individually. We rarerly had a failed verification.
    Anand
    Nov 2006
    Default Yahoo!!!
    Thanks everyone. That was just the help I needed. Based on your stories, I built a jig that parallels the output of a pickit 2 to 5 PIC16F688s. Works great. Thanks for adding years to my life.
    Default Verification anyone...?
    And they all verified? I haven't looked at the programming spec in a long time but I'll throw this out there. Parallel programming like this is frowned on. Fanout can be a problem from the programmer, but more importantly because of the acknowledge response from the IC during verify.
    In general terms, when you program information is going back and forth between the programmer and the PIC (RB7 specifically during verify IIRC). How do you know which IC is verifying when you have them paralled like this? I'd say, you don't. I think some very "funky" (or another "f" word) things can happen under this scenario.
    You may have got lucky by stacking a few devices, but if you are programming more than a couple, for anything more than your own use (I wouldn't want to know that something I bought had been programmed this way) I'd rethink this. Commercial gang programmers are readily available for doing this. These don't simply parallel all the pins; they usually have some dedicated circuitry so that each processor is programmed on it's own.
    Head over to Microchip and search on ICSP; look at the process that takes place during a program cycle.
    EDIT: I did the leg work for you (wasn't hard, went to the page of the device and looked for programming spec). Anyway, look at this: http://ww1.microchip.com/downloads/e...Doc/41204H.pdf
    When programming RB7 is flipping back and forth between input/output. Play that out across 2 devices...5...10?
    Nov 2006
    Default Hmmm...Ok but.....
    Thanks for the heads up, Mtripoli. I haven't yet done this simultaneous programming (5 devices only) extensively, but it has worked about 20 times in a row with no problems. Although I have verified devices a few times, I do not plan to do so much in the future. But before each one goes into the field, I run a diagnostic which, among other things, should indicate whether the PIC got programmed.
    I'm not sure what I'm supposed to see in the programming protocol you linked. I sort of read through it, but nothing caught my eye as a danger. I don't have an RB7 on my PIC and I didn't see any others in the document that used RB7 for programming. I think I will verify the first 100 units and if there are no problems, just continue on. I'll still do the diagnostic, of course.
  1. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  2. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  3. Programming Pins of PICs?
    Last Post: - 15th August 2007, 18:59
  4. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 23:47
  5. Programming Multiple PICs Simultaneously
    By Archangel in forum General
    Last Post: - 16th January 2007, 19:42
