My PIC program won't work! Plz Help?!
Results 1 to 3 of 3
    Mar 2010
    Unhappy My PIC program won't work! Plz Help?!
    Hey guys, i wrote a program in assembly for the 80C51 and it worked but now i have to write the same one for the PIC16F84A in assembly language, and it just wont work. Can someone figure out what mistakes i did?
    This program controls one 7-segment display to count from 0-9 whilst the other 7-segment display to count from 9-0 at the same time.
    Thanks for any help.
    LIST P=16F84
    INCLUDE "P16F84.INC"
    __CONFIG _XT_OSC & _PWRTE_ON & _WDT_OFF & _CP_OFF
    RADIX HEX
    PORTB EQU 0x06
    PORTA EQU 0x05
    R1 EQU 0x0C
    R2 EQU 0x0D
    R3 EQU 0x0E
    ORG 0
    MOVLW 0x1F
    TRIS PORTA
    MOVLW 0x00
    TRIS PORTB
    CLRF PORTA
    CLRF PORTB
    REPEAT: MOVLW 0x0F
    MOVFW PORTB
    MOVLW 0x0F
    MOVFW PORTB
    PA_0: BTFSC PORTA,0
    GOTO PA_0
    CALL DISP
    BTFSC PORTA,0
    GOTO PA_0
    MOVLW 0x06
    MOVFW PORTB
    MOVLW 0xF6
    MOVFW PORTB
    CALL DISP
    MOVLW 0xDA
    MOVFW PORTB
    MOVLW 0xFE
    MOVFW PORTB
    CALL DISP
    MOVLW 0xF2
    MOVFW PORTB
    MOVLW 0xE0
    MOVFW PORTB
    CALL DISP
    MOVLW 0x66
    MOVFW PORTB
    MOVLW 0xBE
    MOVFW PORTB
    CALL DISP
    MOVLW 0xB6
    MOVFW PORTB
    MOVLW 0xB6
    MOVFW PORTB
    CALL DISP
    MOVLW 0xBE
    MOVFW PORTB
    MOVLW 0x66
    MOVFW PORTB
    CALL DISP
    MOVLW 0xE0
    MOVFW PORTB
    MOVLW 0xF2
    MOVFW PORTB
    CALL DISP
    MOVLW 0xFE
    MOVFW PORTB
    MOVLW 0xDA
    MOVFW PORTB
    CALL DISP
    MOVLW 0xF6
    MOVFW PORTB
    MOVLW 0x60
    MOVFW PORTB
    CALL DISP
    GOTO REPEAT
    DISP: MOVLW 1
    MOVFW R3
    LP3: MOVLW 0x0F
    MOVFW R2
    LP2: MOVLW 0x0F
    MOVFW R1
    LP1: DECFSZ R1
    GOTO LP1
    DECFSZ R2
    GOTO LP2
    DECFSZ R3
    GOTO LP3
    ;At blast time, select:-
    ;memory unprotected
    ;watchdog timer disables
    ;standard crystal (4MHz)
    ;power up timer on
    Question
    Hi, Zammi
    first : note here is NOT the best place to ask about Assembler ... much better about PicBasic ... !!!
    with my limited skills, ...
    I really wonder what you try to do with all those lines groups ... :
    MOVLW 0x06
    MOVFW PORTB
    MOVLW 0xF6
    MOVFW PORTB
    Mar 2010
    the aim of my project was to change the 80C51 code program into the PIC assembly language..the original program in assembly language og the 80C51 was this:
    dis1 equ P1.0
    dis2 equ P1.1
    org 00h
    ljmp main
    org 30h;
    main: mov r2,#0FCh
    mov r3,#0FCh
    acall disp
    mov r2,#060h
    mov r3,#0F6h
    acall disp;
    mov r2,#0DAh
    mov r3,#0FEh
    acall disp;
    mov r2,#0F2h
    mov r3,#0E0h
    acall disp;
    mov r2,#066h
    mov r3,#0BEh
    acall disp;
    mov r2,#0B6h
    mov r3,#0B6h
    acall disp
    mov r2,#0BEh
    mov r3,#066h
    acall disp;
    mov r2,#0E0h
    mov r3,#0F2h
    acall disp;
    mov r2,#0FEh
    mov r3,#0DAh
    acall disp;
    mov r2,#0F6h
    mov r3,#060h
    acall disp;
    sjmp main;
    disp: mov r4,#0ffh;
    loop: mov r5,#0f0h;
    loop1: mov a,r2;
    clr dis2;
    cpl a;
    mov P2,a;
    setb dis1;
    nop;
    nop;
    mov a,r3;
    clr dis1;
    cpl a;
    mov P2,a;
    setb dis2;
    djnz r5,loop1;
    djnz r4,loop;
    clr dis1;
    clr dis2;
    ret;
  1. Replies: 14
    Last Post: - 8th November 2010, 11:50
  2. Simple Blink program doesnt work.
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 1st March 2009, 20:30
  3. Making Program Code Space your playground...
  4. Replies: 14
    Last Post: - 26th September 2007, 05:41
  5. Will This program work
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 22:45
