sonar
Results 1 to 8 of 8
Thread: sonar
    Apr 2007
    Default sonar
    i'm using an ultrasonic SRF05 range finder sensor along with pic16f876 and a couple of LDR sensors.
    i'm using the sonar module to detect objects above my robot.
    if distance >= 4 then
    m_detection = 0
    'stop
    m_detection = 1
    'move forward
    end if
    The problem is as follows:
    if an object is at a distance of more than 4inches then it stops, if the object is < 4inches away then it moves forward, this is working as it should. The problem happens when there is no object at all - the motors just shudder :S
    now also if i comment out the LDR code the sonar appears to work...
    Sonar Ping :
    sonar:
    '---------PING----------------------------------------
    sonarcontrol = 1 				 'module on
    trigger = 0
    pulsout trigger, 1
    pulsin echo, 1, range 			 'measure high state
    if range <> 0 then	  			 'if pulsin times-out it returns 0
       distance = range /  15 		 'convert: 15=inches at 4MHz
    end if
    sonarcontrol = 0 	  			 'module off
    Reading the LDRs
    check_LDR:
      HIGH portb.4 'Right_LDR               	  'Make right CDS pin high
      PAUSE 3                      	 	  		  ' Let cap charge
      RCTIME portb.4, 1, LDR_Right_RCdata 		  ' Time & record discharge time
      HIGH portb.5 'Left_LDR                	  'Make left CDS pin high
      RCTIME portb.5, 1, LDR_Left_RCdata   		  ' Time & record discharge time
    LDR_Right_Val =  NCD LDR_right_RCdata
    LDR_Left_Val =   NCD LDR_left_RCdata
    i've been struggling with this for some time now and i'm fairly confused.. any pointers would be very helpfull
    thanks
    jim
    Nov 2009
    Fitchburg, Mass
    Default Did you ever get the SRF05 to work?
    Jim,
    I have been struggling with PULSOUT and PULSIN with a SRF05. The PULSIN command is writing zero into the range register even though my oscilloscope shows a perfectly good response coming from the proximity sensor.
    Did you resolve your problem almost three years ago?
    Ken Jones
    Jim,
    Ken Jones
    I did a bunch of sonar stuff on a little robot years ago so was intrigued by your post. I haven't used the SRF05 but found a little info about it at http://www.robot-electronics.co.uk/htm/srf05tech.htm.
    I'd ask a couple of questions based on what you're seeing:
    When using PULSIN what is STATE set to? It looks like the response from the SRF05 is a high pulse so STATE has to be set to a "1". The manual says "If the pulse edge never happens or the width of the pulse is too great to measure, Var is set to zero.
    What is the period of the PULSOUT command. The SRF05 doc says it needs to be a minimum of 10uS. That's a "1" for a 4MHz osc.
    Are you doing anything between the trigger pulse (PULSOUT) and the PULSIN? If so you may be blowing right by the leading edge and the PIC is seeing nothing so it returns a zero in VAR.
    The manual also says "The resolution of PULSIN is dependent on the oscillator grequency. If a 4MHz oscillator is used, the pulse width is returned in 10uS increments. (Paraphrase) "if 20Mhz pulse width is 2uS". OSC value has no effect on PULSIN. What is the width of the pulse coming back?
    Answering those to start should get you on the right track...
    Mike Tripoli
    May 2008
    Italy
    jim, instead to take one sample at the time, from your sonar, take several samples and average them, to have a more reliable reading and as conseguence a more reliable behavior of your robot.
    Al.
    We have several PBP code examples for the SRF04 (works the same as the SRF05), and
    using photocells in our Micro-Bot projects section you might find helpful.
    http://www.rentron.com/Micro-Bot/Sonar.htm
    Main page: http://www.rentron.com/Micro-Bot/index.htm
    -Bruce
    tech at rentron.com
    Apr 2007
    wow a blast from the past.
    Does it normally take 3years to get a response around here
    i cant remember the ins & outs of it now but it looks like there are some good suggestions posted
  1. Replies: 23
    Last Post: - 23rd September 2008, 19:20
  2. PIC based SONAR
    By PICtron in forum Off Topic
    Last Post: - 3rd February 2005, 22:44
  3. sonar transducers
    By cjsanders in forum mel PIC BASIC Pro
    Last Post: - 24th November 2004, 12:37
