12F683 ADcin = binary outcome!
Results 1 to 4 of 4
    Mar 2009
    Default 12F683 ADcin = binary outcome!
    I'm a struggling learner who took a few months out of all this - I wish I hadn't now!
    Anyway, I'm re-starting with a different (simpler!) chip - a 12f683 - just getting back to the basics right now....AtoD.
    I found some code posted by Bruce on here that I shamelessly used (changing the pins to suit my setup)...
    @MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON
    @MyConfig = MyConfig & _MCLRE_OFF
        CMCON0 = 7          ' Disable comparator
        ANSEL = %00000010   ' Set GPIO.1 to A/D
        ADCON0.7 = 1        ' Right justify for 10-bit
        TRISIO = %00000010  ' GP.0 = serial out, GPIO.1 = A/D in, rest outputs
        DEFINE OSC 8            ' Internal 8MHz
        DEFINE DEBUG_REG GPIO   ' Define DEBUG port
        DEFINE DEBUG_BIT 0      ' Set GPIO.0 as DEBUG serial output pin
        DEFINE DEBUG_BAUD 9600  ' DEBUG baud rate = 9600 bps
        DEFINE DEBUG_MODE 0     ' 1 = inverted, 0 = true
        DEFINE  ADC_BITS 10     ' 10-bit resolution
        DEFINE  ADC_CLOCK 5     ' Set clock source to Frc/16
        DEFINE  ADC_SAMPLEUS 50 ' Sample time in uS before A/D is started
        Quanta  CON 1251        ' For 10-bit A/D +Vref = 5V : 5V/1023*256=1.251=Quanta
    ' PIN# NAME     USE & CONNECTION
    '  1   Vdd      +5VDC power supply
    '  2   GPIO.5   N/C (N/C = NO CONNECTION)
    '  3   GPIO.4   N/C
    '  4   GPIO.3   N/C
    '  5   GPIO.2   N/C
    '  6   GPIO.1   A/D input pin
    '  7   GPIO.0   Serial output pin to PC serial port RX pin
    '  8   Vss      Power supply ground (also connect to DB-9 pin #5)
    ADval  VAR WORD	' A/D result
    MAIN:
        ADCIN 1, ADval      ' Read A/D
        DEBUG DEC ADval DIG 3,".",DEC3 ADval,"V",13, 10
        PAUSE 500
        GOTO MAIN
    the thing is it'll read 5V for 0V presented on pin 6 GP1 (I view the AtoD result using the PICkit 2 Usart tool)- but nothing in between (only two states!)
    Any ideas please before I just give this all up as a bad job and turn to constructing replica stately homes out of discarded matchsticks.
    Hi Hank. . .
    try ADCON0 = %10000111
    it POR defaults to 0 0 0 0 0 0 0 0
    Bits 3:2
    00 = GPIO.0 AN0
    01 = GPIO.1 AN1
    10 = GPIO.2 AN2
    11 = GPIO.3 AN3
    Bits 1:0
    Bit 0 , 0 = disabled 1 = enabled
    Bit 1, 0 = A/D completed or not in progress 1 = ready to do for you
    Mar 2009
    Hi Joe,
    I tried your recommendation - couldn't get it to work.
    I think it might be something to do with leaving the Pickit2 programmer attached as a 'virtual' serial connnection to my PC - so I moved the AtoD over to AN3 (pin 3)..
    This code seems to work...
    DEFINE OSC 4           ' Internal 8MHz
    DEFINE ADC_BITS 8      ' 8-bit resolution
    DEFINE ADC_CLOCK 2     ' Set clock source to Frc/32
    DEFINE ADC_SAMPLEUS 50 ' Sample time in uS before A/D conversion is started
    CMCON0 = 7   			'Comparators off
    ADCON0 = %00000001		'ADC enabled and right justified
    ANSEL = %00001000		'GPIO.0 and GPIO.1 analog input
    INTCON = 0				'INTERRUPTS off
    TRISIO = %111011		'GPIO2 output
    GPIO = %00010000 		' All outputs = 0 on boot
        ADval  VAR WORD	    ' A/D conversion result
        MAIN:
        ADCIN 3, ADval      ' Read A/D
        DEBUG DEC ADvAL,13 ,10
        PAUSE 200
        GOTO MAIN
    Many thanks for your help.
    Quote Originally Posted by HankMcSpank View Post
    Hi Joe,
        MAIN:
        PAUSE 200
        GOTO MAIN
    OK, if you are going to use @MyConfig, you are missing the most important piece, under @myConfig you must have the config statement directing it to use MYConfig
    like so:
    @_MyConfig = _INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_ON
    @_MyConfig = MyConfig & _MCLRE_OFF
    @ __config MyConfig
    And @ _MyConfig must have 1 underscore and no spaces between the @ symbol and the underscore.
    I suspect if that worked for you then doing it this way will give an overwriting previous address error, because your code is still using the default config.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  3. Delayed output 10 secs
    By lilimike in forum mel PIC BASIC Pro
    Last Post: - 14th October 2011, 06:28
  4. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  5. Working with indivividual bytes of an array
    By J_norrie in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2007, 19:16
