MCSPlus serial interface to EasyPIC6 not working?
Results 1 to 34 of 34
    Mar 2009
    Colorado
    Question MCSPlus serial interface to EasyPIC6 not working?
    Am not able to get serial communication from MCSPlus with EasyPic6 while running program on 18F4550.
    I set the SW6 and SW7 for RC7 & RC6 respectively per the User Manal and MCU data sheet for the EUSART in the 18F4550. I also made sure the host computer had the COM1 serial interface set to 9600 BPS, 8 data bits, no parity and one stop bit (8N1) .
    The MCU was programmed using MCSPlus as the editor, PICBASICpro as the compiler, and MPASM as the assembler to create a .hex file, which was then burned into the MCU using a USB interface from PICFLASH to the EasyPIC6.
    After programming I have then been trying to use ICD that is built into MCSPlus to step the source code and monitor variable values, which requires the serial interface connection between the MCSPlus host and the EasyPIC where the program is running in the PIC18F4550. I keep getting a serial interface timeout when I start the ICD in MCSPlus even though I have made sure the seral interface is defined in the code and the PC's serial settings have been set to match the MCSPlus settings of COM1.
    Can you please advise from above info what I am doing wrong that is causing the serial interface to timeout without connection??
    Does the easypic hava a level shifter (RS232) chip? If not you will need one using the PIC's USART.
    And
    with out seeing your configs and code we have no way of knowing if the chip is running at the speed you think it is.
    Mar 2009
    Colorado
    Question Answers to your questions and here are the configs
    Yes it has a MAX202 chip installed on the EASYPIC6 board.
    Sorry about that...I see now I referenced my configs but forgot to include them. Here they are. One other relevant piceof info: the Easyic6 has a 8 MHz crystal installed for the MCU. I realize the DEFINE in the code must tell the compiler what the MCU clock is, and in this case I intend on this code using a USB interface, which is set by configs for the 48 MHz USB clock. Therefor the DEFINE to tell the MCU it is a 16 MHz MCU clock.
    I have also tried both HYPERTERM and the USART Terminal that comes with mikroelectronica's EasyPic6 to see if the terminal makes a diference....they both never connect and timeout.
    Would appreciate any advice you can give me.
    ASM ; 18F2550/4550, 8mhz crystal
       __CONFIG   _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC4_PLL6_1L & _USBDIV_2_1L
       __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG   _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG   _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
       __CONFIG   _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
       __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 16
    Try defining the OSC at 48.
    I am not near my data sheets , on a phone, so I am not sure if you have the PLL correct. But if you do have it PLLed to 48 then that is what you set the define as.
    I use the same chip with a 4 external and run it at 48.
    DEFINE OSC 16 should work with your config settings. If you're trying to use the MCS+ ICD, make sure you compile with the ICD/Compile button. If you're just trying to verify the connection with HSEROUT, then use the normal Compile button.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2009
    Colorado
    Default Tried your suggestons..no success
    I tried both 48 and 16 MHz defines and also made sure the recompiles were with just the Compile button and not the Compile/ICD button.
    I also generated a simpler program to test the serial inteerface that just reads the HSERIN from the PC host and then resends the same received character to the PC host with HSEROUT (see included code below). The PC host hyperterminal says the sends are going out, but never receive back any resends from the PIC. I also included in the HSERIN statement a timeout to a label that blinks LEDs as an error if timeout occurs. It does, so it confirms that the serial interface is not working and is timing out.
    Almost seems like a hardware failure on the EasyPic6 side, but I don't want to RMA the EasyPic6 all the way back to Rumania to have them check/repair the unit due to the time delays and the cost....the EasyPic6 is my development board....just wish I could get the serial interface to it working so I could then use the MCSPlus ICD debugger with it.
    At this point I am really baffled. Any other suggestions as to how I can verify the serial interface?
    ' -----------------------[ Program Description ]--------------------------
    ' Program is for a PIC18F2550/4550 & was tested in an EasyPic6 board.
    ' PICBASIC PRO program to send and receive from the hardware serial port
    ' LEDs count characters and flash error if none received for 10 seconds
    ' -------------[ Revision History ]--------------------------------------
    ' Version 1.0   Started on 03/04/2012
    '--------------[ Define EEPROM usage ]-----------------------------------
    ' -----[ Device Declaration ]---------------------------------------------
    ;--- if you un-comment these, you must comment the ones in the .inc file--
    Include "Modedefs.Bas"
    INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
                                ' User must make sure the AllDigital.pbp file
                                ' is in same directory location as this source
                                ' code before compiling.
        'DEFINE SHOWDIGITAL 1    ' When uncommented will show analog settings
                                ' in Assembler Results window
    DEFINE OSC 16
    DEFINE I2C_SLOW 1   ' Set i2c to the standard speed
    DEFINE I2C_HOLD 1   ' Enable recieving i2c device to pause communication
    '--------------[ Declare Variables, Aliases & Constants ]---------------
        ' Variables & Aliases for Pins
    char	Var	Byte		' Storage for serial character
    cnt	    Var	Byte		' Storage for character counter
        ' Constants
    ' Initialize Hardware
        'Set registers
       	TRISB = %11001111	' Set PORTB.4,5 to outputs
    	PORTB = 0		    ' Turn off LEDs
    	cnt = 0			    ' Zero character counter
        ' Setup Hardware for uart
            'DEFINE HSER_BAUD 9600
            'DEFINE HSER_RCSTA 90h
            'DEFINE HSER_TXSTA 24h
            'DEFINE HSER_CLROERR 1
        ' * NOTES for use with EasyPic6 development board:
       ' Set SW7.1 on for RC7 = RX and SW8.1 on for RC6 - TX
        'For use with COG 2x16 LCD:
        '   - Turn on Port Expander switches SW6.1,SW6.2,SW6.3,SW6.4 & SW6.5.
        '   - Turn on COG LCD 2x16 switches SW10.1,SW10.2,SW10.3,SW10.4,SW10.5
        '     and SW10.6.
    ' Set EUSART configuration for serial interface to EasyPic6
    ' For MCSPlus ICD debugging only....comment out for operations
        'TRISC.6 = 1
        'TRISC.7 = 1
        'RCSTA.7 = 1
    '--------------------[ Begin Main Program Loop ]------------------------
    mainloop:
        PAUSE 100 ' Without this PAUSE, there's nothing to keep the Watch Dog
                  ' Timer clear. LOW & GOTO don't generate CLRWDT instructions.
                  ' See www.picbasic.co.uk/forum/showthread.php?p=84722#post84722
        Hserin 10000, allon, [char]	' Get a char from serial port..if timeout go
                                    ' to label as error
        Hserout [char]		' Send char out serial port
    	cnt = cnt + 1		' Increment character count
    	PORTB = cnt << 4	' Send count to LED
    	Goto mainloop		' Do it all over again
    allon:	PORTB = %00110000	' Error - no character received
    	Pause 500		' Blink all LEDs
    	PORTB = 0
    	Pause 500
    	Goto allon
    End     ' Safety measure to insure program stops if reaches here
    Below are the setting for 9600 baud at 16MHz
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $20 ' Enable transmit, BRGH = 0
    SPBRG = 25  ' 9600 Baud @ 0.16%
    You have the ones in your code commented out.
    Run this code and type numbers at the keyboard.
    DEFINE OSC 16
    ADCON1 = 15		' All I/O pins digital
    X VAR BYTE
        START:
        RCSTA.4 = 0 : RCSTA.4 = 1
        RCSTA=$90:TXSTA=$20:SPBRG=25
        HSERIN [DEC X]
        HSEROUT [DEC X,$d,$a]
    GOTO START
    On SW7 & SW8 flip everything else to the OFF position leaving only switches #8 on each one ON. Does it work?
    In: http://www.mikroe.com/pdf/easypic6/e...anual_v100.pdf the photo in Figure 6-1 shows both DIP
    switches for RC6 & RC7 on switch positions #1.
    And just below this in Figure 6-2 they show RC6 & RC7 on DIP switch positions #8. Which is right?
    -Bruce
    tech at rentron.com
    Mar 2009
    Colorado
    Default Ran your code
    DEFINE OSC 16
    PORTB.6 = 0                 ' Turn off the LEDs PORTB.7 = 0
    X VAR BYTE
        START:
        HSERIN [DEC X]
    GOTO START
    Mackrackit, I created a .pbp file from your above code with a slight modification where I inserted a LED turn on just after the HSERIN and just after the HSEROUT statements. See the code below. Then when running the code and typing characters on the keyboard I do not see these respective lights come on in the EasyPic6. This says the HSERIN and the HSEROUT statements are never executing when the code is running and the PC terminal is connected. This implies a hardware failure somwhere in the EasyPic6 serial interface circuitry....do you agree???
    DEFINE OSC 16
    TRISB = %00001111	' Set PORTB.4,5,6,7 to outputs as test LEDs
        PORTB.7 = 0
    X VAR BYTE
        START:
        HSERIN [DEC X]
        PORTB.6 = 1         ' Turn on PortB.6 LED if this statement is executed
                            ' as test of receiving a character
        PORTB.7 =1          ' Turn on PortB.7 LED if this statement is executed
                            ' as test of HSEROUT having sent a character
    GOTO START
    Mar 2009
    Colorado
    Default Tried both ways...I think 1st photo is correct.
    Tried it both ways, Bruce, while running Mackrackit's code as I modified it above. And as I said in above post to him, no LED test lights turned on, indicating the HSERIN and HSEROUT statements never executed....meaning no receipt of the character I typed on the keboard by the HSERIN.
    Any other ideas?
    I always include DEFINE HSER_CLROERR 1 if using HSERIN just to be sure it' never locked up on me, but I'm not sure that's the problem.
    Try sending first. Something like HSEROUT ["Hello World",13,10] to MCS terminal. If this doesn't work, then try using SEROUT2 PORTC.6,84,["Hello World",13,10].
    If you get nothing on screen, I would check my connection from RC6 to the PC side of the MAX IC, serial cable, etc.
    If you have an O-Scope set it in a continuous HSEROUT loop while watching the MAX TX out pin to PC.
    -Bruce
    tech at rentron.com
    Mar 2009
    Colorado
    I will try those ideas, Bruce.
    Got to wondering if the MCU was actually running. I can see from the PRG light on the EasyPic6 it is getting programmed but in previous code didn't have any way to confirm it was actually running....if it weren't that could explain why the test LEDs didn't light in previous post and also possibly why the HSERIN and HSEROUT statement aren't executing...hence no communications.
    I inserted a blinking LED in the loop in the below version and when I run it, it doesn't blink...indicating the MCU is not running!! Now I don't know what to do to make the MCU run.?????
    DEFINE OSC 16
        PORTB.5 = 0
        PORTB.7 = 0
    X VAR BYTE
        START:
        PORTB.5 = 1         ' Blink LED as test that MCU is running
        HSERIN [DEC X]
        PORTB.5 = 0
    GOTO START
    I've never used this board, but it looks like there's a ton of jumpers on there. And if you're not getting even an LED to blink, I would bet you're just missing a jumper setting!
    Might even try replacing the PIC.
    Is the POWER LED ON?
    -Bruce
    tech at rentron.com
    Mar 2009
    Colorado
    I just burned a test program into the chip via same programming path I've been using that is a "blinky LED". It works fine. This tells me that at least the MCU chip will run and is OK. However, from what I saw that I described in my previous post, the serial interface code is NOT running in the MCU. Don't know why it would run with one program and not the other???
    [/QUOTE] Yes it is.
    I just was wondering if it might be the USB to Serial converter cable I have to use because the Laptop I am using doesn't have a true serial (RS232) interface connector. I am using an ATEN UC232A USB-to-serial converter cable that connects to the DB9 connector on the EasyPic6 serial interface. It has a light built in to the serial end of the cable that comes on when the TX and RX switch selections are correct on SW7 and SW9 and the MCU is powered up. I have heard before that some of these USB to serial cables don't always work with some serial interfaces. Have any ideas about this one?
    If that isn't it, then it is looking more and more like a failure in one of the compnents in the EasyPic6 serial circuit.....possibly the MAX202 they use...just don't know how to text the circuit to see if it is a H/W failure.
    I'm really running out of ideas.
    You could test the board by removing the PIC and VERY VERY carefully plug a jumper wire in across the PIC TX/RX pin sockets. That will give a loop back to the PC when something is sent.
    And/or
    Program the chip, put it ina breadboard then connect to the PC. If you have the hardware.
    Use SEROUT2 with an inverted MODE then an inverter chip is not needed. Send "hello wold" like Bruce mentioned.
    Jump pins 2 and 3 at the USB/serial converter and do a loop back test.
    With out an "O" scope, write a code to send something in a loop, something long. with a second pause between sends. Connect a DVM to zero and serial pin #2 of the EasyPic and see it the is any activity from the on-board inverter chip. If the DVM fluctuates then the inverter chip is probably working.
    Mar 2009
    Colorado
    Tried this and got no loop back to the PC terminal display. Also put an O-scope on the jumper and see no activity when typing characters on the PC keyboard. That tells me no transmissions are reaching the RX pin on the MCU on the EasyPic6...possibly MAX202 or USB-to-serial cable bad?
    [QUOTE]
    [\QUOTE]
    Did this and type characters at the PC keyboard and no loop back characters on the RX side of the terminal. Also connected an O-scope to Pin-2 of the Male DB9 connector (TX from PC) and no activity when typing characters on PC keyboard. This test tells me that the UC232A cable (USB-to-serial) is probably not wired correctly for USB to serial conversion. It still doesn't eliminate the MAX202 as the problem.
    .....Connect a DVM to zero and serial pin #2 of the EasyPic and see it the is any activity from the on-board inverter chip. If the DVM fluctuates then the inverter chip is probably working.
    By this do you mean connect the DVM to check for voltage at the MCU's RX pin socket location on the EasyPic6 with the MCU removed? I don't undersand which serial pin #2 you are referring to. It seems to me that connecting to the RX socket location would also confirm whether the inverter chip is working as long as I know the cable is good. Would appreciate your clarification on that.
    Serial pin#2 would be the RX from the test board. I did not know that you have an O scope.
    Write a code to send serial data and connect your scope to the EasyPic board. That will tell you if anything is getting out.
    Mar 2009
    Colorado
    Default EasyPic6 serial interface works w/ mBasic but not PBP??
    Have made some progress in isolating the problem. Finally found a laptop with true serial interface so I could avoid use of USB-to-serial adapter cable. To confirm EasyPic6 interface was working I programmed a PIC16F877 chip with the standard loopback test mikroBasic code that came as sample with the EasyPic6. With this code the serial interface worked fine. This confirms there is nothing wrong with the serial interface hardware in the EasyPic6. For reference here is that simple code:
    ' * Project name:
    '     UART (Simple usage of UART module library functions)
    ' * Copyright:
    '     (c) Mikroelektronika, 2009.
    ' * Revision History:
    '     20080930:
    '       - initial release;
    '       - 20090720 - modified by Slavisa Zlatanovic;
    ' * Description:
    '     This code demonstrates how to use uart library routines. Upon receiving
    '     data via RS232, MCU immediately sends it back to the sender.
    ' * Test configuration:
    '     MCU:             PIC16F887
    '                      http://ww1.microchip.com/downloads/en/DeviceDoc/41291F.pdf
    '     Dev.Board:       EasyPIC6
    '                      http://www.mikroe.com/en/tools/easypic6/
    '     Oscillator:      HS, 08.0000 MHz
    '     Ext. Modules:    -
    '     SW:              mikroBasic PRO for PIC
    '                      http://www.mikroe.com/en/compilers/mikrobasic/pro/pic/
    ' * NOTES:
    '     - RX and TX UART switches on EasyPIC6 should be turned ON (SW7.1 and SW8.1).
    program UART
    dim uart_rd as byte
      UART1_Init(9600)                     ' Initialize UART module at 9600 bps
      Delay_ms(100)                        ' Wait for UART module to stabilize
      UART1_Write_Text("Ready")
      UART1_Write(10)                      ' Line Feed
      UART1_Write(13)                      ' Carriage Return
      while (TRUE)                         ' Endless loop
        if (UART1_Data_Ready() <> 0) then  ' If data is received,
          uart_rd = UART1_Read()           ' read the received data,
          UART1_Write(uart_rd)             ' and send data via UART
        end if
      wend
    end.
    Then I programmed my 18F4550 with the below PBP code that is an adaptation I got from Mackrackit. Although the code compiles and runs, the serial interface doesn't work....no character loopbacks to Hyperterminal when typed and an oscilloscope connection to the RX pin of the 18F4550 shows nothing when characters are typed into Hyperterminal.
    I have studied the code in both cases and see little functional difference. Yet one works and the other doesn't.
    Can anyone advise me what changes to make to the PBP code to get it to work??
    'ASM ; 18F2550/4550, 8mhz crystal
    '   __CONFIG   _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC4_PLL6_1L & _USBDIV_2_1L
    '   __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    '   __CONFIG   _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    '   __CONFIG   _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    '   __CONFIG   _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
    '   __CONFIG   _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    'ENDASM
    DEFINE OSC 16
    'Register Settings
        TXSTA = $24   ' Enable transmit, BRGH = 1
        SPBRG = 160   ' 9600 Baud @ 16MHz, -0.08%
        SPBRGH = 1
    '    BAUDCON.3 = 1 ' Enable 16 bit baudrate generator
        TRISB = %00000000	        ' Set PORTB to outputs as test LEDs
        PORTB = 0               ' Turn off the LEDs
        HIGH PORTB.4            ' Blink the one Test LED as proof MCU is running
        PAUSE 500
        LOW PORTB.4
    ' Declare variables
    X VAR BYTE
    START:
        HSERIN [DEC X]
        PORTB.5 = 1         ' Turn on PortB.6 LED if this statement is executed
        PORTB.6 =1          ' Turn on PortB.7 LED if this statement is executed
    GOTO START
    Hint:
    There are 2 buttons available in mister-e's program ...
    Post #7 ??
    Exactly, post #7 is a good example of the same problem.
    Setting registers, instead of DEFINEs for HSERIN/OUT.
    Post #7 should have the correct settings.
    What is wrong with setting registers? I do this at times when I need to change the baud rate on the fly.
    Hmmm, suddenly I was in a world where everything was reversed.
    Such as using defines when reading RCREG.
    Turned into setting regs when using HSERIN.
    Strange ... very strange ...
    OOPS
    Mar 2009
    Colorado
    Default Change in approach to troubleshooting UART interface
    Hint:
    OK, I judge by the exchanges between DT and Mackrackit that I should have used the DEFINES button with Mister_e's PICMultiCalc. So I did. However, as a change in approach to my troubleshooting to isolate this UART problem with my PBP code, I have taken the following approach:
    1) Since I know that my EasyPic6 UART interface works with the sample loopback routine that came with it that is written in microelekBasic (see earlier post) for a 16F887 chip, I have discarded my 18F4550 chip for now to see if I can get PBPro code that is functionally identical to the microBasic routine to also work with the 16F887 chip in the EasyPic6.
    2) I have insured the _configs for my code result in the identical config bits that are generated by the microBasic code with the EasyPic6.
    3) Please see this PBPro code below and note the configs that appear to be equivalent to the microBasic version and also how I used PICMultiCalc to define the UART setup and then studied the data sheet for the 16F877 to make sure it was correct, as shown by my extensive commenting of the UART setup.
    4) I then programmed the 16F887 chip using MCSPlus, PBPro 2.6 compiler, MPASM assembler, and the PICFLASH interface to actually download the .hex file to the chip. PICFLASH also permits me to double check the configs before burning the chip.
    5) After the chip is running, I then tried HYPERTERM to type some characters over the interface. Nothing indicated on HYPERTERM in the received loopback, although this same process worked with the microBasic routine.
    6) Also tried the comm interface in MCSPlus to communicate with the running code and although it showed that the typed characters were accumulating in the TX tally at the bottom of the screen, no characters were being tallied in the RX entry. SAME PROBLEM AS OBSERVED WITH 18F4550!!
    7) In all of the above cases I assured that both the PC and the PIC ends of the EUART interface were set to COM1/9600/8bits/no parity/1 stop bit.
    The continuing failure of the PBPro code, that is as close to identical to the microBasic code as I can make it, is very frustrating to me!
    Can anyone see what is wrong with this PBPro code to cause it to continue to fail in this loopback test between a PC terminal and the running PIC??
    ASM ; 16F887, 8mhz crystal
       __CONFIG    _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _IESO_ON & _FCMEN_ON  & _LVP_OFF & _CP_OFF & _BOR_OFF
    DEFINE OSC 8
    'Register Settings
        TRISC.6 = 1             ' EUSART control will automatically reconfigure
        TRISC.7 = 1             ' these pins from input to output as needed.
                          ' RCSTA.7 = SPEN = 1 for Serial port enabled (configures
                          ' RX/DT & TX/CK pins as serial port pins).
                          ' RCSTA.4 = CREN = 1 for Asynchronous Continuous Receive
                          ' Therefore RCSTA = %10010000 = 90h
    DEFINE HSER_TXSTA 20h ' Enable transmit, 8-bit, Asynchronous mode
                          ' TXSTA.5 = TXEN = 1 for Transmit enabled
                          ' TXSTA.4 = SYNC = 0 for Asynchronous mode
                          ' TXSTA.2 = BRGH = 0 for High Speed Asynchronous Baud Rate
                          ' Therefore TXSTA = %00100000 = 20h
    DEFINE HSER_SPBRG 51  ' 9600 Baud @ 8MHz, 0.16%, , 51 = 33h = %00110011
    SPBRGH = 0
    BAUDCTL.3 = 1         ' Enable 16 bit baudrate generator
        PAUSE 500               ' at tiime of power up.
        LOW PORTB.4
    ' Declare variables
    X VAR BYTE                  ' Variable holds received character from UART
    START:
        HSERIN [DEC X]
                            ' as a test of receiving a character.
                            ' as a test of HSEROUT having sent a character.
    GOTO START
    Hang in there. We will get it working.
    But
    Where's the code?
    Mar 2009
    Colorado
    Default Here is the code for previous post
    OOPS
    I'd like one of those too, please
    I have pins
    RC7 connected to MAX232 pin 12
    RC6 connected to MAX232 pin 11
    MAX232 pin 13 connected to DB9 pin3
    MAX232 pin 14 connected to DB9 pin2
    Both of the codes below do the same thing. I do not have an EasyPic board but this has been tested on breadboard.
    '16F887 HERSIN/OUT
       @ __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
       OSCCON = %01110000
       DEFINE OSC 8
       DEFINE HSER_SPBRG 51  ' 9600 Baud @ SPBRGH = 0      25 FOR 4MHz
       X    VAR BYTE
       RUN:
       HSERIN [X]
       HSEROUT [X,$d,$a]
       GOTO RUN
    '16F887 HERSIN/OUT    #2
       OSCCON = %01110000
       BAUDCTL.3 = 1
       X    VAR BYTE
       RUN:
       RCSTA=$90:TXSTA=$20:SPBRG=51
       HSERIN [X]
       HSEROUT [X,$d,$a]
       GOTO RUN
    May 2008
    Italy
    Did you check the cable connecting the two units? There is the possibility that you have Rx connected to Rx. See the attached picture.
    Al.
    Mar 2009
    Colorado
    Default RX is connected to RX in my cable
    Quote Originally Posted by aratti View Post
    Al.
    I used a multimeter to check the connectivity on each pin of the DB9 connectors from the male end to the female end of my cable. My cable is wired as a straight through connection...in other words:
    Male Pin Female Pin
    2-RX 2-Connected (as RX?)
    3-TX 3-Connected (as TX?)
    5-GND 4-Connected as Gnd
    7-RTS 7-Connected as RTS
    8-CTS 8-Connected as CTS
    This appears to be the case you warn about where RX is connected to RX. Yet this cable works OK as a serial interface with the EasyPic6 when running their sample microBasic coded loopback example when using Hyperterminal or other terminal emulators. However, when I connect it to the EasyPic6 and try to run any of the PicBasicPro codes listed in the above posts, the HSERIN statement does NOT receive a character and hence no loopbacks.
    I checked the schematic for the EasyPic6 and the female DB9 connector is wired to the MAX202 chip as shown in the attached schematic (Pin2 to T1 OUT and Pin3 to R1 IN). That means that from the PC end of the cable RX is wired to T1 OUT and TX is wired to R1 IN, which I would interpret to be a correct interface. However it doesn't work with the PicBasicPro HSERIN statement.
    Does all this mean that my cable straight through connections will work with mikroBasic and the EasyPic6 interface, but will not work with the HSERIN statement in PicBasicPro and the EasyPic6 interface??
    Here is my current code. It executes OK down to the HSERIN statement as evidenced by the clearing of the LCD in the statement just before the HSERIN. But it confirms that the HSERIN statement is not executing because the LCDOUT statement just after the HSERIN is never executing when characters are typed at the terminal emulator, and the heartbeat LED in the mainloop is never blinking.
    Can anyone tell me why this HSERIN statement is not executing with this interface? I am very frustrated at this point!
       __CONFIG    _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_OFF & _MCLRE_ON & _CP_OFF & _IESO_ON & _FCMEN_ON  & _LVP_OFF & _BOR_OFF
    OSCCON = %01110000
                                ' in Assembler Results window.
        ' A/D & Comparators disabled for digital ops
            ' All of these statements should be commented out when using the
            ' INCLUDE "AllDigital.pbp" statement to set digital ops.
                'ADCON1 = %00001111
                'CMCON = 7
    DEFINE OSC 8
    'Register Settings
        TRISA = 0               ' PortA connections are used for LCD interface
        TRISC.0 = 0             ' PortC.0 is used for a Heartbeat LED
        TRISC.2 = 0             ' PortC.2 is used for the LCD R/W connection
    SPBRGH = 0
    ' Make sure that SW6.8 on the EasyPic6 is set to ON position before powerup.
    ' Make sure that SW7.1 & SW8.1 on EasyPic6 are set to ON before powerup.
    ' Initialize the display
        Pause 500       ' Wait for LCD to startup after power on
        GOSUB InitializeDisplay
        PAUSE 500               ' at time of power up.
        LOW PORTB.4
    ' Declare variables
    mainloop:
        PORTB.5 = 1            ' Turn on PortB.5 LED if this statement is executed
                               ' as a test of entering START loop
        Lcdout $fe, 1          ' Clear LCD screen
        PORTC.0 = 1            ' Blink Heartbeat LED during mainloop
        HSERIN [DEC X]
        Lcdout $fe,1,"RCVD"    ' Display RCVD on 1st line
        Pause 500              ' Wait .5 second
        PORTC.0 = 0
        PORTB.6 =1             ' Turn on PortB.6 LED if this statement is executed
        LCDOUT $fe,$C0,"TXMTD" ' Jump to 2ne line & show TXMTD
        Pause 500
    GOTO mainloop
    ' ----------------------[ START LIST OF SUBROUTINES ]-------------------
    InitializeDisplay:      ' Commented out till LCD installed
    '--SETUP FOR USING 2x16 LCD THAT IS INSTALLED IN EASYPIC6-----
      ' LCD DEFINES FOR USING 2x16 LCD with PortA in EASYPIC6
       DEFINE LCD_DREG PORTA      ' Use PORTA for LCD Data
       DEFINE LCD_DBIT 0          ' Use lower(4) 4 bits of PORTA
                                      ' PORTA.0 thru PORTA.3 connects to
                                      ' LCD DB4 thru LCD DB-7 respectively
       DEFINE LCD_RSREG PORTA     ' PORTA for RegisterSelect (RS) bit
       DEFINE LCD_RSBIT 4         ' PORTA.4 pin for LCD's RS line
       DEFINE LCD_RWREG PORTC     ' LCD read/write port
       DEFINE LCD_RWBIT 2         ' LCD read/write bit
       DEFINE LCD_EREG PORTA      ' PORTA for Enable (E) bit
       DEFINE LCD_EBIT 5          ' PORTA.5 pin for LCD's E line
       DEFINE LCD_BITS 4          ' Using 4-bit bus
       DEFINE LCD_LINES 2         ' Using 2 line Display
       DEFINE LCD_COMMANDUS 1500  ' Command Delay (uS)
       DEFINE LCD_DATAUS 44      ' Data Delay (uS)
        ' DEFINE LCD Control Constants
            K       CON $FE           ' Control Byte ($FE)
            Clr     CON $01           ' Clear the display
            Line1   CON 128           ' Point to beginning of line 1 ($80)
            Line2   CON 192           ' Point to beginning of line 2 ($C0)
        ' Test the LCD during initialization
            LCDOut K,CLR:Pause 50              ' Clear Display
            LCDOut K,Line1+3," LCD TEST "      ' Display "RTC TEST" on 1st line
            Pause 500
            LCDOut K,Line2+2,"..Power On.. !!" ' Display "Power on" on 2nd line
            PAUSE 1000
    Yes , you need a cable that goes from
    2 to 3
    and
    3 to 2
    and
    5 to 5
    Go down to radio shack and get a couple of connectors. Roll you own.
    Mar 2009
    Colorado
    Wink Problem found...but don't know why?
    By comparing Mackrakit's two codes in his above post to what I was trying to do, I noticed that he used the statement "HSERIN [X]" whereas I had been using "HSERIN [DEC X]". When I changed this statement in my code to match his the serial interface works! But I don't know why? I see in the PBP manual that DEC is a legitimate modifier for the HSERIN statement. How come it doesn't work in my code?
    Mar 2009
    Colorado
    2 to 3
    and
    3 to 2
    and
    5 to 5
    In fact, as I tried to describe in my above post, the way the MAX202 is wired in the EasyPic6 to the Female DB9 connector it does crossover the 2 to 3 and 3 to 2 pins from the cable so that the signals are correct when they get to the MCU. See the schematic I posted above.
    Thanks so much for all your help with this. I would appreciate an explanation of my question regarding HSERIN [X] versus HSERIN [DEC X].
    I did not get the cross over part of your other post...
    The DEC thing
    If like this
    'Only numbers will work
    HSERIN [DEC X]
    'Letters and numbers
    HSERIN [X]
    HSEROUT [X,$d,$a]
    'Only receive numbers and output ASC||
    '66 will return B
    HSERIN [DEC X]
    HSEROUT [X,$d,$a]
    'Will receive letters and numbers and output decimal
    'B returns 66 and 13 -- carriage return
    HSERIN [X]
  1. Please help with EDE702 - Serial to LCD interface
    Last Post: - 30th October 2008, 02:48
  2. 32-bit Quadrature Counter With Serial Interface
    Last Post: - 10th June 2008, 02:49
  3. Serial interface with RFID reader
    By brid0030 in forum Serial
    Last Post: - 23rd January 2007, 06:23
  4. Replies: 0
    Last Post: - 25th November 2005, 14:35
  5. PIC16F877 to RFID Module Serial Interface
    Last Post: - 17th May 2005, 06:03
